40T Starter
JB
03-03-2004 07:36:21
The starter on my 40T sometimes will not turn over until I tap the case with a small hammer.My tractor had been converted to 12V before I got it. It starts good when the starter engages.Would this probably be an easy fix, or should I go ahead and have it rebuilt. Thanks, JB
JB
03-03-2004 10:39:47
 Re: 40T Starter in reply to JB, 03-03-2004 07:36:21
Thanks for the help. Nice to know what to look for.
John T
03-03-2004 16:40:21
 Re: Re: 40T Starter in reply to JB, 03-03-2004 10:39:47
Youre certainly welcome, just mess with her a while and you can probably finger her out lol. Try loosenign and tightening the starter bolts etc and if that or flywheel movement cures her again, suspect a sticking drive. If flywheel rotation or loosening dont affect her much but a hard hammer blow helps, Im thinking maybe a starter/brush problem.
John T
John T
03-03-2004 09:55:12
JB, Its hard to tell whether or not its an easy fix as you asked, but I will throw out a few "maybe" easy things to try which might only be a temporary band aid cure OR may even fix the old girl, nuttin ventured nuttin gained.
If possible, lets determine if its an Electrical Problem, like worn or dirty or sticking brushes,,, or a faulty switch or starter post (sorta doubt it for now) or a plain old bad starter,,, ORRRRR R a Mechanical Problem, like maybe a sticking/hanging starter drive as Wayne mentioned.
MECHANICAL PROBLEM
1) As good ol Wayne there mentioned, it could be a sticking/hanging starter drive. In my opinion, when you use 12 volts on a 6 volt starter the added initial higher torque kick is a lil tougher on the drives. As far as possibly any easy fix, you might remove the starter and clean and light lube the starter drive and see if that helps. If not and its a bad drive versus an electrical problem (see Para. 2) the drive may need replaced.
MECHANICAL VERSUS ELECTRICAL PROBLEMS
a) When she fails to start, if you can get the engine rocked (flywheel moved) versus a hammer rap, does that seem to release the sticking????? ? If so, sounds like a sticking/hangin starter drive problem.
b) Orrrrr rr does it take the hammer rap (maybe electrical problem like brushes) to get her to crank, but the hammer shock could still still be releasing the drive similar to turning flywheel. If moving the flywheel releases her, sounds like stuck drive, but a hammer blow could still be EITHER mechanical or electrical??
ELECTRICAL PROBLEMS
2) When she fails to start, as youre trying to start her and have the lights on, do they go way dim or remain unchanged as youre trying but she wont start???
a) If the lights DONT go dim, and a hammer rap then makes her start, the brushes could be bad. You may get by with a good clean out and clean the commutator and make sure the brushes are not worn down too low and not hanging. Worth a try.
b) If the lights DO go dim, the switch is making contact and it could still be an electrical problem ORRRRR R the drives stuck (COULD STILL BE EITHER, but if moving the flywheel fixes it, sounds like a stuck drive, while if it takes a hammer rap, it could still be a bad drive or bad starter (maybe brushes).
c) If the lights DONT go dim, the starter switch may be burned or carboned ORRRRR the starters post may be burned or carboned. You could remove the starter switch and see if its not burned or carboned and likewise the switch contactor. A burned or carboned switch contactor or the starter post could be the cause of non starting when the lights dont dim, but more often if a hammer rap makes her work, bad brushes or a stuck drive comes to mind. i.e. a hammer rap wont usually fix a burned switch or starter post problem
SUMMARY
You have to see if its a stickign drive (lights would go dim and rockign flywheel frees her) ORRRRR R an Electrical Problem
--Hammer rap sounds like brushes OR stuck drive
--Flywheel turning fixes, sounds like bad drive
--Lights dimming sounds like switch okay, may be bad starter OR still bad drive
--Lights NOT dimming, sounds like bad switch or starter post burned or carboned (doubt that for now) but could still be brush problem.
Try some of the above procedures to see if its a mechanical or an electrical problem and post back or e mail me your findings and I will try my best to help you.
If the lighs dim and rocking the flywheel fixes it, I suspect a sticking drive.
If the lights dont dim and a hammer rap fixes it, it may be bad brushes.
I suspect a bad switch or starter post is not the problem (still worth checking into) since a hammer rap is less likely to fix that then it is a stuck drive or a bad brush problem.
If I were a betting man, Id go with a sticking drive (esp if lights go dim) or bad brushes based on the limited info we now have to go on. A hammer rap could fix bad brushes or a stuck drive is the problem.
Let us know, Good luck n God Bless
John T
Wayne in Tn.
03-03-2004 08:29:36
JB, that is a common problem on those Dubuques, the starter drive or (bendix) is hanging in the flywheel. Sometimes you have to loosen the mounting bolt and pull the starter back some, then bolt it back in.
You could have bad teeth on the flywheel, but usually a new starter drive will fix the problem. The Carquest number for the drive is D27C, just pull the starter and it can be replaced easy.
