jdemaris
03-03-2004 12:01:07
Re: Re: Glow plugs for JD in reply to buickanddeere , 03-03-2004 06:55:04
Not everyone can park their tractor, all the time, near an electricity source - so a blockheater is not always the answer. We had lots of starting problems with Deere tractors, used and new. We had some brand new tractors at the dealership that started awful. We tore down quite a few, experimented a bit, in efforts to get better starting and worked alongside with a few Deere tech. guys. This cold starting problems peaked with the 40 series ag. tractors, but existed before that. In fact, my neighbor bought two brand new 4020s back around 1970- ordered them identical. One has always been a great starter and never had a block heater. There's no power where he keeps it. It will start down to zero with ether. It does have a manual pump destroker. The other 4020 never started well. At zero it would hardly even smoke without ether. After 11,000 hours we rebuilt it. At that time, we raised the fuel delivery, and also decreased the valve recess in the head. Made no difference. He finally got rid of it and just kept the good one. Things got much better when the 50 series came out. First of all, I've seen very little correllation between fuel injectors themselves, and cold starting - if they are working at all. I've pulled apart excellent starting tractors that had injectors that were worn out and dribbled instead of sprayed and were running at low pressure. We also farted around with batteries, injection timimg and delivery, valve recess in cylinder head, piston standout, etc. &c. Main problem was poor machining tolerances at the Deere factory. General rule of thumb with any of the Deeres that use a closed-center radial-piston hydruaulic pump. Have of way of destroking it and the tractor will start better. In my world, a three dollar manual pump shut-off beats the $400 electric destroking kit. The three dollars also saves a lot of starter motors. Next subject is firing pressure/compression. We found, and still find, that if a tractor started well when new, it probably always will with proper maintenance. If it was a dog when new, good luck! Deere came out with special repair kits with graded overheight pistons to fix the problem. They worked, but I wonder how many times these tractors wind up getting an in-frame rebuild, and get standard pistons stuck back in.
