Luke, on the staying running problem??.. That could be as simple as the fuel system having a restriction problem.. Have your mechanic check the rubber fuel hose for a restriction [that�s a common problem on those old pony�s].. Then look for a plugged strainer screen in the fuel door strainer assembly.. If nothing found in the fuel supply then have him make sure the oil pressure shut-off is functioning correctly [if it has one].. If You are getting a good fuel supply all the way to the carb, then suspect a plugged carb passage [common if the float has started to disintegrate] or an ignition problem.. There could also be a float height issue if there was a new float installed as the replacement floats seem to be too low if set by the original carb spec sheet [try raising the float level a little if you have a later replacement float]..~If you have an ignition problem it might be hard to find as those pony plugs are difficult to get to.. What I use is an old metal core plug wire & piece of clear rubber hose.. Take the old plug wire & cut it in the middle some where, then strip back about �� of the insulation, then push both cut halves into a 1-1/2� piece of clear hose, push the metal wire ends to be within about 3/16� of each other .. Then install that [special wire] between a pony spark plug wire & the spark plug.. What that does is allow you to see the spark as the engine is running so you can see if the spark quits as the pony quits.. ~Now on timing the pony?? Start by making sure both sets of points are gapped at .020� on the high part of the distributor cam.. Then remove the inspection cover over the top of the pony flywheel, then remove the # 1[front] spark plug, then use a screw driver & turn the pony flywheel Counter Clock Wise until the ring gear & clutch housing V marks line up [><] while #1 is coming up on compression, then loosen the 4 pony distributor screws & rotate the pony distributor Clock Wise as far as possible, then turn the pony ign switch on, then hold #1 plug wire about 3/16� away from the pony engine block [put a paper clip in the plug wire first], then s-l-o-w-l-y turn the pony distributor CCW [looking from the distributor end] until you get a spark.. It is now timed� AS EASY AS THAT��. OK, now the cautions: DON�T leave the pony ignition on for more than a very short time or you risk burning the pony coils up [a very easy thing to do].. The other thing to keep in mind is the pony flywheel timing mark is on the flywheel ring gear & there is always the chance that has moved, been installed incorrectly, or otherwise not being where it�s supposed to be.. ~You might want to print this out & hand it to your mechanic if he isn�t familiar with Deere pony motors.. Post back or E-Mail with any questions� [email protected]
