Clamp Question
Tim...OK
03-02-2004 10:30:28
third party image
It's me again. :-) My 38 A came with one rear clamp,can't read the part number on it very well,but it appears to be B1961R. Anybody recognize this clamp or number? Is it actually an "A" clamp? 36" round spokes. Thanks ya'll.
Tim
Clooney
03-02-2004 13:03:00
 Re: Clamp Question in reply to Tim...OK , 03-02-2004 10:30:28
Tim, the guy you need here is Duane Larson..
~Until he can chime in here & help I can give you enough to probably confuse both of us..
~According the info I have the B1961R rear clamp was used with the AA 3861R, JD 1263R, JD 1264 R, JD 1270R & JD 1271R..All JD A wheels.... From what I can gather the AA 3861R was a pressed steel & the others were flat spoke replacement wheels from the mid 1940's Deere A's.. Those would retro-fit back to the un-styled tractors..
~It also seems that B1961R clamp was used on some 1939-46 Deere B's with some wheel combinations...
~I'm sure there's more but this is about all I have on that clamp...
[email protected]
Duane Larson
03-02-2004 12:44:09
Tim,
It looks like you have a bolt-in hub on a round spoke rear wheel. Is there a casting number on the wheel hub like HC391A or D? Is there a number on the bolt-in hub, like A2994R? These two pieces of information will help pin it down. It is possible the original cast-in hub was broken, and a bolt-in hub adapted to the wheel. The B1961R clamp was used primarily on bolt-in hubs.
Clooney
03-02-2004 13:08:04
 Re: Re: Clamp Question in reply to Duane Larson, 03-02-2004 12:44:09
Sorry Duane, I should have refreshed before posting,, didn't see you there already..
Tim...OK
03-02-2004 13:23:52
 Re: Re: Re: Clamp Question in reply to Clooney , 03-02-2004 13:08:04
I knew i could count on you two to set me straight. I guess I should have added that the cast in hub on both wheels honestly looks like it's been torched out,so that makes perfect sense. Thanks for verifying that part number,now i know for sure what I need to get for the other side. Thanks a bunch Clooney and Duane,always look forward to your posts.
Tim
Duane Larson
03-02-2004 14:52:37
 Re: Re: Re: Re: Clamp Question in reply to Tim...OK , 03-02-2004 13:23:52
Tim,
Glad to help - it is not uncommon to find broken ears on hubs and that was a standard fix. If done nicely it looks good.
No problem, Clooney! Been there, done that, probably with you.
