Have questions about john deere D
RedandGreen
03-02-2004 05:47:58
Was wondering if anyone ever ran a thasher with one? is belt speed to much coming of the belt pully at full governed speed? Also is there plenty of power to run a sawmill smooothly? The sawmill at the shows I go to will lug down a 50hp Case steam engine so I was wondering how the D would do on such a mill, The 65HP case does real well thogh on this mill. The model D im asking about would be a styled D around 1947
Will P
03-02-2004 14:20:37
 Re: Have questions about john deere D in reply to RedandGreen, 03-02-2004 05:47:58
Well, I run my 1924 22X36 Case with my 43B with 21 HP. It is alittle under powered so we have to pitch bundles alittle slow. Have had an unstlyed A with 28 HP, and that was nice. Had a late styled A on it and it ran it like it was belted to nothing. So a D should have no problem. But, my B was running at 900 rpm's to run the thresher at 1050 rpm's that is specified. With a bigger pulley on the tractor (D), the tractor will have to run slower. Find a thresher with a bigger drive pulley size. Better to match that bigger belt pulley on the D.
Onto the saw mill, one of my friends put his 730D on the saw mill. Really gave her a workout. Was in my opinion, alittle under power. He also put his late 820D on the saw mill. Handled it better than the 730. Blew the carbon out of both of them.
Anything else, just holler.
Will P
David from Kansas
03-02-2004 10:51:34
RedandGreen,
When I was a kid my father and uncle owned a Case thresher and I remember using our 37 D to power it, and they also used my Uncle's DC Case. We also used the D on a buzz saw to cut hedge (osage orange) into posts and firewood and it worked good on that also. David
Ralph - Wi
03-02-2004 06:53:29
On any belt driven machine a Deere will require a larger driven pulley than most tractors of that vintage. On "silo filler" we had about a 22" pulley, I'm guessing the neighbors had a 12 - 15" pully with a WC Allis. There were "over pulleys" made which increased the diameter of pulleys on threshing machines. It was a split pulley (two C-shaped sections). A neighbor sawed lumber with a D for years, and there were others that used D's in the county. They would not keep up to a fifty horse steamer. The torque on a steamer continues to rise as the speed decreases, reaching the maximum when it is stopped dead.
