43 A ENGINE HANGIN UP DURING STARTING
HANK
03-02-2004 00:06:22
SWEET RUNNING OLD A, BUT IT SIEZED UP WHILE CRANKING. I PUT A CHEATER BAR ON THE FLYWHEEL
AND YANKED. IT TURNED LOOSE. I AM WORRIED ABOUT WHY IT DID THAT.
THE SOLINOID WAS WEAK, BUT DON'T KNOW WHAT MADE
IT STICK AS SHE DID.
Lee
03-02-2004 01:40:30
 Re: 43 A ENGINE HANGIN UP DURING STARTING in reply to HANK, 03-02-2004 00:06:22
Starter bushings may be worn too much causing too much clearance between the bendix gear and the flywheel gear? I will say that this does tend to show up more when the battery is weak or starting speed is slow now that I think of it. Hasn't happened here in a long either, but it did once. Just before I worked on the starter and got an alternator put on my 43 A.
Turn your Caps Lock key off - all capitals is considered to be the same as shouting in computer newsgroups and forums.
