JD 4020D Hydraulic pump
farmerherron
03-01-2004 18:23:27
Just bought a '65 4020D Synchro. Was told engine was rebuilt within last 1000 hours, does run strong and sound nice. However there is a lound knock coming from front of tractor, pretty sure it was hydraulic pump so took off coupler from motor and ran motor-no more knock. The knock increases with engine speed, seems loudest when at idle. All hydaulic functions, steering, braking, 3 point, work great. Is my pump going, bad bearing in coupling shaft? Any help would be greatly appreciated.
Thanks
will
03-02-2004 07:39:00
 Re: JD 4020D Hydraulic pump in reply to farmerherron, 03-01-2004 18:23:27
It may be just the pump itself. Is it a very high hour tractor? On my late model we replaced two couplers trying to quite it down, but it ended up just needing a pump rebuild. It is incredibly quite now. It is a bit of a hastle to pull the pump. I believe we had to pull the frontend off. IT is also somewhat costly to have it rebuilt (about 600 dollars). I would definitley try the other ideas listed below first. The best of luck.
Brokenwrench
03-02-2004 03:51:53
If it is not the bushings or splines as mentioned below,it could also be a slight internal hydraulic leak in one of the systems in the tractor. This will cause the pump to stroke slightly,giving you the knock you hear.
JimKS
03-01-2004 19:01:08
If the hydraulics aren't jerky, I'd suspect that the splines where the pump shaft goes into teh coupler are loose. There should be a couple of bolts to tighten the splines onto the pump shaft,adn you shoudln't be able to move it when those bolts are tight. If you had the coupler off, I think you'd have noticed if the rubber bushings were bad.
jdemaris
03-01-2004 18:55:03
Did you check the coupler parts? First of all, there are four little plastic bushings that wear out. Once they do, the machine will knock like crazy until you put a load on the hydraulic pump - like turning the steering wheel or using a remote hydraulic. Real easy job to change them. Also, the splines on the metal part of the coulpler can get loose where is fastens to the pump. Light duty couplers have two bolts to clamp it tight, heavy duty coulplers have four. As far as the pump itself, not too complicated - if it comes to that. There is one internal part, that can be changed without removing the pump, that will get real noisy after a while - but will be more of a chatter than a knock. It can also make the tractor start hard - because it turns over hard - because it's pumping too much hydraulic oil at cranking speed - I'm referring to the stroke-control valve.
