JD-A heads
arnold r
01-22-2004 05:04:27
yesterday I replaced the head on my 46-A with one off a late A, (none water pump model) when I went to put the rocker arm shaft on I run out of adjustments. I measured the head and it was 5-1/4 inches thick, the one that came off was 5-1/2, the one on my other 46 is 5-1/2, and I have a cracked late A head and a heisler that are 5-1/2. This one didn't seem to have been planned that much as there was still space between the head surface and the valve ibrows, I made a spacer to fit between the rocker and head and it works good, but what models had the 1/4 inch thinner head? thanks for any info.
