H hydraulic pump
J.P.
03-01-2004 06:27:35
Before I start, let me say that I have already ordered the Parts manual. My question is: We have a little less than two H's to find one; both have hydraulic control units. Recently I have seen pictures of two other tractors without hydraulics. Was this an option and if so what was used to cover the place that the hydraulics mounted? Would a switch to no hydraulics require more than a simple plate or cap? Is there a shaft & bearing involved?
dan_41jdh
03-01-2004 15:29:09
 Re: H hydraulic pump in reply to J.P., 03-01-2004 06:27:35
third party image
Here's a picture of the area in question. This tractor is an early model (pre H-10000) without the optional hydraulic pump. The LH governor bearing housing is of the older flat style. As Clooney mentioned, the later versions bulged out to accept the extended governor shaft which was designed to engage the optional hydraulic pump. The platform is back far enough from the governor/pump area to avoid needing to be notched or otherwise modified to clear the pump.
Clooney
03-01-2004 16:41:39
 Re: Re: H hydraulic pump in reply to dan_41jdh, 03-01-2004 15:29:09
Dan, your picture shows the difference in the platform.. Those two holes showing in the upper L/H corner weren't in the mid 1941 & under platforms as they mount the platform extension.. I don't believe that platform extension will fit with the hydraulic pump in place.. I knew there was some difference in that pump corner but I think it must be that platform extension & not the actual platform....
[email protected]
dan_41jdh
03-02-2004 05:11:31
 Re: Re: Re: H hydraulic pump in reply to Clooney , 03-01-2004 16:41:39
Clooney, you are correct on all counts. The platform extension won't fit a tractor with a hydraulic pump, and the extension isn't necessary in that case because the pump creates a similar barrier against oil slinging.
That tractor in the picture was at the John Deere Collectors Center in Moline a couple of years ago. Although without a serial number plate, it was thought to be one of the first seven units. However, there were quite a few details on the tractor that weren't accurate for the date of manufacturing, including the more recent platform with the holes for the platform extension.
Clooney
03-01-2004 10:05:07
J.P., on the early H's the hydraulic pump was a retro-fit by using the later longer governor shaft & pump drive parts.. On the later H's it was an option..
~To remove the hydraulic pump is easy.. Just remove the pump & install the later governor cover [the one with the long shaft cover snout]..OR you can cut the shaft off [or install the early shaft] then use the flat governor end cover.
~I don't have a parts book handy [not sure it will show it anyhow] but I believe the floor pan is cut back in the pump area on the pump equipped H's..
[email protected]
