1951 B clutch getting hot
Todd
02-29-2004 17:38:28
I was driving my 1951 B and it was the first time is was really driven since a restoration. After about 20 minutes, the clutch was smoking. It has new clutch disks in it, and is adjusted to have the distinct "click" when engaged/disengaged. I didn't do too much to the clutch when I restored it except the new disks. Any ideas on what would cause this? I was thinking maybe a bad bearing?? Thanks.
Clooney
02-29-2004 17:55:58
 Re: 1951 B clutch getting hot in reply to Todd, 02-29-2004 17:38:28
Todd, if that clutch is snapping in good I doubt the clutch itself is smoking. It probably isn't bearings either as the bearings are not turning on their races when the clutch is snapped in. The outer bearing & inner bushing only work when the clutch is snapped out & the crankshaft is spinning inside the pulley hub..
~If the smoke is coming from behind the clutch pulley & not from under the pulley cover my guess is your engine has blow-by that is coming out from behind the clutch pulley..
~There is no seal behind the clutch pulley in your "B" so any combustion blow-by that exists in the crankcase can exit behind the clutch pulley..
~I presume you installed new piston rings when you restored the tractor so maybe they just haven't seated in yet.. Put the tractor to work for a while & see if the rings seat & the smoke goes away..
~Another reason you could have smoke is moisture in the crankcase that's burning off & coming out from behind the clutch pulley..
[email protected]
Todd
02-29-2004 17:59:42
 Re: Re: 1951 B clutch getting hot in reply to Clooney , 02-29-2004 17:55:58
Clooney,
I guess I forgot to add that the pully itself is hot to the bare hand. I can only hold my hand on it for a few seconds before it gets too hot. The engine has new pistons and rings. Thanks again.
Clooney
02-29-2004 18:15:53
 Re: Re: Re: 1951 B clutch getting hot in reply to Todd, 02-29-2004 17:59:42
Todd, where is the smoke coming from? Under the cover or from behind the pulley??
~Any chance the pulley brake is hanging up & rubbing on the pulley?..
[email protected]
Todd
02-29-2004 18:53:46
 Re: Re: Re: Re: 1951 B clutch getting hot in reply to Clooney , 02-29-2004 18:15:53
The smoke is coming from under the cover (inside the clutch). The brake isn't touching the pulley. When I touched it, the pulley and cover were too hot to touch for more than a few seconds.
Clooney
03-01-2004 03:07:15
 Re: Re: Re: Re: Re: 1951 B clutch getting hot in reply to Todd, 02-29-2004 18:53:46
Todd, well with that information it really does sound like you have a slipping clutch.
~See if you can tighten it a little more so it snaps in harder..
~If it still makes heat when pulling you will have to disassemble it again & make sure the clutch plates are installed correctly..
~It probably wouldn't hurt to check the crankshaft end play [needs to be around .005"-.010"].. But it would have to quite excessive to cause clutch problems..
~I still doubt you have a clutch bearing problem especially if the clutch releases good & the pulley doesn�t want to spin with the clutch disengaged.
[email protected]
RUSS
03-01-2004 12:49:09
 Re: Re: Re: Re: Re: Re: 1951 B clutch getting hot in reply to Clooney , 03-01-2004 03:07:15
Todd; I think Clooney has well covered this gremlin. Been awhile since I had my 48 JD B.
At one time I had too much oil in my engine case, maybe a quart over the telltale. The excess oil made its way to the inner clutch facing and also some onto the drive pulley facing. In 5th or 6th gear it white smoked pretty good.
I leveled the tractor and let it drain from the telltale for an hour or two.
This made a smoking difference and I increased the hand clutch snap a bit also.
When you did the clutch assembly did you pull the pulley off and replace the inner friction disc?
My B needed to be slowly coaxed (clutched) to bring on the power in 5th or 6th gear. Don't know
if this was typical or it was just in a poorer operating condition due to wear or poor adjustment.
Good luck on your smokin' situation.
