JD 4520
Williet
02-29-2004 15:15:26
Looked at a JD 4520 yesterday and I wanted to know what it was worth, it has 8,900 hours on the engine,a canopy,3-pt hitch,two SCV's,and big tires.Also what kind of problems should I look out for on this tractor.
mike
03-01-2004 03:20:05
 Re: JD 4520 in reply to Williet, 02-29-2004 15:15:26
sold a good one last summer,7,000 hrs,1 new rear tire, ratty cab. 7000$
4520 Owner
02-29-2004 17:38:58
Just purchased a early model 4520 last fall for $5900, open station, wide radial tires about 70%. Runs good but had to replace seat, belts, water pump, and front engine seal. The late model 4520 is worth more than the early model, it has all the upgrades that went into the 4620. The early model 4520 has the injection pump on the right rear of the engine, the late model has the pump on the right front. It would have the 404 engine which is in the 4020-4630,7520. Its just a heavy tractor.
37D
03-01-2004 08:02:19
 Re: Re: JD 4520 in reply to 4520 Owner, 02-29-2004 17:38:58
Think you just made a "typo", the 7520 has a 531ci engine, but the 7020 had the same 404 that was used in 4630's
