Quick clue to tell you if it is poor grounding is, turn on all 4 lamps. Since you say you have new lamps grounded to the fender via bare metal using pop rivets, connect one of your jumper cables to the grounded battery terminal. Clamp the other end onto a screwdriver. Touch the screwdriver to the bare connection at your pop rivets & see if the lamps get brighter. If yes, you have a ground problem. IF no, look for bad connections in the supply wiring including the light switch proper. -Another way, turn on all 4 lamps. Using a good volt meter, measure the voltage at the battery (plus post to minus post) and record that voltage. Next, check the voltage at any lamp by checking between the feed wire and the grounded terminal of your battery. Don't just measure across the lamp, measure from the lamp's hot post to the grounded terminal of the battery! From hot post of the lamp to battery ground should be within a fraction of a volt of battery voltage. If you see voltage at the bulbs a volt or more less than battery voltage, check supply wiring, connectors including the switch for high resistances. -If bulb voltage matches battery voltage (within a volt) disconnect a lamp on one fender. If that fender's other lamp gets significantly brighter but here is little change in voltage on the volt meter, it's a ground problem. -If there is a significant increase in voltage at the remaining bulb when one is disconnected, then it's most likely a high resistance in the supply wiring. -I have found tractors with their light wires connected incorrectly at the switch letting them work only through a dim lights resistor. Could be they're wired to the wrong post of the switch. Good Luck.
