Tim, first of all, did it smoke ONLY AFTER you hooked it up and turned the ignition on, or you mean it smoked even before you turned the ignition switch on????? ????? Some initial smoke could simply be paint and/or oil etc burning off, since they do run fairly warm. Their mechanical mounting can help conduct their heat away also versus if hanging in free air. It should be in the vicinity of 1 to 2 ohms and 20 to 30 or so watts, if it were drastically rated different, it could be drawing more than intended current and overheating. As you know I assume, the ballast is wired from the ignition switch IGN output,,,,, and then wired to the coils high (not to distributor) side input terminal. On its "to coil" terminal or else the coils input terminal (same electrical point) there is a wire coming up from the starter which is HOT ONLY when cranking. Thats the start by pass circuit so the coil receives full unballasted voltage when cranking. *****OVERCURRENT AND OVERHEAT POSSIBILITIES***** If its not the normal heat and initial burn off 1) If it smokes when the ignition is on, maybe its not wired right and has its output direct to ground instead of to the coil (and then ground) as it should be????? ? The series circuit should be out the ign switch,,,,, to and through the ballast,,,,, to and through the coils primary (lil + and - terminals),,,,,to the distributors points to ground (when closed). 2) If it smokes when ignition is on, another possibility is if the wire up from the starter was accidentally grounded (posed to be HOT when cranking) it would again conduct current straight to ground versus through the coil then ground. (more resistance, less current and heat) 3) If it smokes when ignition is on, another possibility is the coil is shorted out or mis wired etc whereby its drawing approximately twice its intended current and maybe overheating. The ignition circuit is supposed to be 1 to 2 ohms of ballast and another 1 to 2 ohms of coil resistance, whereby at 12 volts there's 4 amps through the coil and ballast and they dont overheat. HOWEVER, if the ballast were grounded or the coil shorted or mis wired and the ballast sees full 12 volts across it to ground, it can overheat. They are often a wirewound resistive wire in a ceramic bathtub enclosure which is insulated so they cant short to ground and current and voltage at their terminals. If bad or shorted or grounded or too low resistance, they may overheat. 4) If it smokes when ignition is on, its possible there's a short in its output wire leading to the coils high side (or again in the wire down to the starter). If you place a test lamp or voltmeter on the coils high input side and turn ignition on (if points closed and coil and ballast good) there should be 6 to 8 volts or so on the coils input. IF NOT, there may be a short there which drops the voltage and allows excess ballast current overheating it!!!!! !!!! 5) If it smokes even when the ignition is off, it gettign power to one side and a grouned to the other via some mis wiring problem. Sooooo ooooo, make sure its wired right per above and theres no shorts in its wiring and if the coil is good and not shorted it should run warm but NOT continue a lot of smoking. Post back your e mail if you want me to e mail you a wirign diagram. It should be simple to trace as its only out the switch, to and through ballast, to and through the coil primary, to the distributors points to ground. If theres any dead shorts, the voltage as I described above wont be reading plus the shorted circuit can burn the wire up or blow a fuse etc. Hopefully, its just the new burnign off as they do run warm. They are supposed to copnduct heat away from them via their mechanical mounts. Let me know, Good Luck n God Bless ya Tim John T
