520 LP Convertor questions
Tyler--MO
02-29-2004 09:01:05
Hi again,
I finally got around to rebuilding my M4 LP convertor last night. I had no problems until I got to the shims on the high pressure valve. The kit that I got had 4 or 5 shims (of different thicknesses). There weren't any shims on the valve when I removed it from the convertor. My question is how do I determine what and how many shims to use. Do you have to check the output pressure (6psi)? If so how do you go about doing this? **I do have the JD LP Gas repair manual and it mentions very little on this subject**
~Also on the same note...is there anything that I'll have to do with bleeding the air out of the convertor...what I mean is should I expect an air lock?? For the record I think that I'm gonna use that Dex-Cool that GM uses in their new cars because of its aluminum friendly properties....
Thanks
Tyler in Missouri
alabamafrog
02-02-2009 15:43:56
 Re: Securing the seat in reply to 2cylinder, 01-28-2009 15:42:37
garytomaszewski said: (quoted from post at 19:43:24 01/28/09) Frog,
I'm going to assume that 80 MPH wind is from driving 55 into a
25 mph wind. LOL
I didn�t think about head winds, I guess I need to find some 110mph Velcro.
I usually try to keep it down near 70 when hauling 2 tractors on the interstate but occasionally might bump 80 when passing.
I might do both the tarp strap and put Velcro around the edges, I could keep the tarp strap in the battery boxes with the pipe covers and try to remember to put it on the seats each time I haul them.
This post was edited by alabamafrog at 15:45:28 02/02/09.
