Gear Pattern on Syncro 2510
NewFarmGuy
02-28-2004 21:16:43
Probably a dumb question, but what's a guy to do...
I have a JD 2510 Syncro. The gear pattern is mostly rubbed off, but I think I found a new reverse tonight. I know there is a 3R and 5R, is there a third? If so what is it? 7R?
RUSS
03-01-2004 13:04:14
 Re: Gear Pattern on Syncro 2510 in reply to NewFarmGuy, 02-28-2004 21:16:43
JD 2510; Better get that decal early. My guide says the tractor has 8 forward speeds and 2 reverse speeds. What does the JD repair manual or owners manual have to say?
I don't think John Deere at the drawing board wanted its buyers with implements attached going backward and beating lightning out of the gate.
Good luck on your hunt for shifter normal pattern.
John in Md.
02-29-2004 16:58:16
The old trick is to cut out the gate like third and fifth reverse and hang on. This is not meant as a suggestion just an observation of what others had done in the past.
NewFarmGuy
02-29-2004 12:28:50
Thanks for the info guys. I thought I was loosing my mind when I shifted into what I thought was 5 Reverse and that ol' girl took off like skunk shot coon hound. Must of been 7 Reverse.
The guy that sold me the tractor swears it only has two reverse speeds, sounds like wear in the gear pattern opened the additional gear. John Deeres just keep getting better with age!!!
Ray
02-29-2004 09:26:39
You can buy a new decal for about 50 cents.
New FarmGuy
02-29-2004 12:21:27
 Re: Re: Gear Pattern on Syncro 2510 in reply to Ray, 02-29-2004 09:26:39
Where?
Ray
02-29-2004 13:44:40
 Re: Re: Re: Gear Pattern on Syncro 2510 in reply to New FarmGuy, 02-29-2004 12:21:27
There available from JD or K&K decals in Indiana.
Deere John 2004
02-29-2004 06:59:41
When the New-Generation Deeres came out, there was a lot comments about the shifting pattern. Really, its like shifting 2 transmissions with 1 lever. The first has Park- range 1- range 2- range 3- range 4; you had to come to a complete stop [or were supposed to] to shift that transmission. When you moved the shift lever to the right, throught the gate, the second transmission had a low gear, a high gear, and a reverse. This transmission could be shifted 'on the move', by pushing in the clutch and shifting.[Again, you were supposed to wait for the tractor to stop before shifting into the reverse, but many times in would shift when the gears slowed down enough.] The reverse was locked out in range 3 & range 4 because they were considered too fast[faster then the high gear in that range]. When the shifter gates become worn, you could slip the shifter lever past the block into the reverse in the higher ranges. At this point, on my Dad's 2510, you can actually use the reverse with the 6/8 gear~range 4 if you hold the shift lever tight against the bottom of the dash. This happened by accident to me, but, I don't know who can drive at 15 mph in reverse.
37D
02-29-2004 06:27:53
Don't know about a 2510, but all the 3010's & 4010's I've seen had the reverse off of 7th acessable from the factory. As far as I know the later tractors just didn't have the notch cut in the shifting assembly to allow this, I've heard this was done for safety reasons.
Mike in Mo
02-29-2004 06:18:50
I'll se if I can describe this so it makes sense. At the top is park. the first notch down from that and to the right is 1st (up) and 3rd(down). 3rd reverse is down from that. Second notch down on the left is 2nd and 5th, with 5th reverse down from that. 3rd notch on left is 4th and 7th. sometimes you can get it into 7th reverse, but it should be locked out. the last notch down on the left side is 6th(up) and 8th(down). This may be about as clear as mud, but hopefully this will help you figure it shift pattern out. Mike
