Hydraulic fluid loss + oil level gain. JD 830
Paul
02-28-2004 13:53:03
The subject says it all. The oil does not look like it has water in it, but the level has risen by probably a quart or two above the top fill mark on the dipstick after about 10 hrs of use after an oil change. The hydraulic fluid was topped off to the full mark as well at the same time. Now the hydraulic level is low. I do not see any leaks when it's operating.
Any suggestions on what I should start looking at?
Bob
02-28-2004 23:16:19
 Re: Hydraulic fluid loss + oil level gain. JD 830 in reply to Paul, 02-28-2004 13:53:03
Hydraulic pump shaft seals.
