4520 owners, help me out
Dwayne TX
02-28-2004 09:51:05
I just bought this tractor & like it a lot so far. The hydraulics are jumpy on the way up and the hyd pump makes a chattering noise when the lift is raised. The dealer told me to replace the screen, which(the new one) is a tubular cage surrounded with plastic mesh. He said it should be covered by a plug that takes a 1/2" socket drive to remove. The only thing I can find that resembles this is on the left side of the transmission, behind the transmission filter and the spools with the remote hyd cylinder manual bypass valve. It has the synchro-range transmission.
Is this the plug to remove to replace the screen? The manuals I have don't give much info, except to replace it at 600 hrs.
Bob
02-28-2004 10:10:33
 Re: 4520 owners, help me out in reply to Dwayne TX, 02-28-2004 09:51:05
I believe the plug should be low down on the LH side, just ahead of the big casting the axle shaft comes out of. The open face of the plug where you insert the wrench faces outward from the tractor towards the rear tire. It is at the low point of the rear case, so nearly all of your oil will run out, if you don't drain it first.
Dwayne TX
02-28-2004 10:18:35
 Re: Re: 4520 owners, help me out in reply to Bob, 02-28-2004 10:10:33
Thanks, Bob. That's the same spot I'm looking at. It threw the dealer for a loop when I told him the plug had a hex shaped hole in it instead of square. I'm sure the fluid needs to be changed anyway, so I'll pull the plug/screen and keep my fingers crossed. I appreciate your input.
