2240 Oil Pressure
darrell steinba
01-21-2004 12:01:54
what is the normal oil pressure at idle and at full RPM's for a JD 2240
darrell
01-21-2004 18:55:08
 Re: 2240 Oil Pressure in reply to darrell steinbach, 01-21-2004 12:01:54
thank you David
david val
01-21-2004 14:51:33
regulated pressure is about 60 psi (high rpm), will probably drop to about 30 with a hot engine at low idle. minimum alowed at these conditions by deere about 15 psi. mind you that pressure at low rpm is affected by engine condition as well as oil temp and oil type.
david
