D runs! but.....
Jeff
10-09-2003 19:23:38
After a year long restoration I fired up my 1930 D tonight. I had a valve job done, dixie mag rebuilt, new rings, carb rebuild and paid close attention to the timing. She fires up pretty easily but it will not run at wide open throttle. I rebuilt the DLTX 6 and thought I did a good job of cleaning out all of the passages but maybe not. If I advance the throttle slowly it will almost make it to WOT but when you go all the way it wants to die. I did not mess with the gov at all and maybe this needs a little adjustment? I also see a little back firing at higher RPMs. I didn't use the drill bits to clean the carb passages but I did remove all the plugs and main nozzle and used a stiff wire on them. I thought they were pretty clean but maybe not. Any thoughts?
Sam S.
11-03-2006 20:00:36
 Engine Shop in Mpls? in reply to
Joe Morgan
08-13-2005 16:35:07
 Re: Re: D runs! but..... in reply to Clooney , 10-10-2003 03:22:47
I am looking for a 1951 John Deere D Grille Thank You
Glen in TX
05-15-2006 09:27:48
 Re: 35 B JD Hand Crank Problems in reply to Jak, 05-15-2006 08:47:55
Geeze, I read again in first sentence you said got the carb stem repaired. I hope that worked okay for you and carb is still good. You may want to check that fuel level is 3/4" from top of carb bowl with a hose barb fitting and some clear tubing also. Check timing and maybe even borrow a known good carb to try it also if still not having any luck. Could be carb problems yet? If so check some carb trouble shooting procedures at jdhpubs.com that apply to the H and other letter series JD 2 cylinders. You have a good hot blue spark at clean plugs and not a wimpy yellowish orange spark? Use non resistor spark plugs and metallic core wires for best spark with a magneto.
Magneto Timing for JD D and other Waterloo JD tractors with flange mount magneto :
1. Remove spark plugs from the engine and turn flywheel forward in direction it runs until you feel some pressure of air coming out the LH # 1 cylinder (flywheel side) spark plug hole as it is coming up on compression stroke. (If you don�t feel or hear air coming out it is on exhaust stroke and keep rotating till it comes up on compression stroke.)
2. Turn slowly as it comes up on TDC (top dead center) of compression stroke and watch as the mark on flywheel �L.H. Impulse� comes up in line exactly at the 3 o�clock position with the mark on transmission cover or housing. Stop when marks are in line with each other. (Note): The later model A,B,AR, & 50 tractors with flywheel cover will have a mark or notch on lower end of cover hole to align with flywheel punch mark instead of marks mentioned above.
3. In this position the slot in coupling on governor shaft should be horizontal. If it is not horizontal when LH cylinder is at TDC and governor had been removed previously this will have to be aligned and corrected first.
4. If slot is now in horizontal position you are ready to install the magneto.
5. Make sure points are set at .015� for Edison Splitdorf and Wico magnetos.
6. Edison Splitdorf magnetos when mounted use the forward terminal on distributor cap for # 1 LH cylinder. Can mark with chalk if necessary. 7. Wico magnetos will use the top terminal in distributor cap for #1 LH cylinder. Can mark with chalk if necessary.
8. Connect wires and spark plugs in distributor holes of magneto and have the magneto frame and plugs grounded with plugs out of engine.
9. While turning the magneto slowly in a left hand direction (CCW) facing the drive end watch for a spark from the #1 LH cylinder plug that would be connected to forward terminal on Edison magneto or top terminal on Wico magneto.
10. When you get a spark on the LH terminal stop and the drive lugs of magneto should be in a horizontal position. 11. Being careful to not disturb that position install the magneto on tractor using one or more flange gaskets and install bolts only finger tight.
12. If you notice a binding and magneto flange does not pull up tight to flange when tightening bolts finger tight you may need to shim out with more gaskets being careful drive lugs align in slots also.
13. Then rotate the top of magneto toward the front of tractor as far as possible.
14. Then slowly rotate the flywheel forward one complete turn slowly coming up on the �LH Impulse� mark on flywheel to align exactly again with cover mark at 3 o�clock position. Then stop in this position. 15. If you went past the mark you can rotate the flywheel back and come up on mark again but if you rotated too far forward and tripped the impulse in magneto you will have to remove magneto and start over. 16. Now carefully and lightly tap the top of magneto slowly toward the rear of tractor a little at a time until you hear the impulse trip. Stop.
17. Tighten the bolts holding magneto to governor case taking care to not over tighten. If flange does not pull up flush do NOT over tighten to pull it up more.
18. Use another gasket to shim magneto farther out instead. Failure to heed this advice shimming the magneto properly with gaskets can result in breaking the magneto housing. 19. Problems getting magneto to align by having to use several gaskets may also indicate previous improper assembly of governor or worn governor parts.
20. Gap spark plugs at .030� before installing in cylinders. 21. Install spark plug wires so wire in upper terminal of Wico magnetos or forward terminal of Edison Splitdorf magnetos is connected to the LH cylinder spark plug. Lower or rear wire connects to RH cylinder.
22. If magneto is equipped with a threaded stop terminal you may add a shut off grounding switch to this terminal.
23. NEVER connect battery voltage to a magneto or to stop terminal !
24. A magneto produces it�s own power and does not need power from a battery.
Dick W
10-11-2003 13:22:55
 Re: Re: Re: D runs! but..... in reply to Jeff, 10-10-2003 06:24:36
Jeff - Make sure the cork float is not hanging up inside the bowl. I bought one from Deere and it shrunk up to about half size after sitting in gas for awhile. I ended up buying another from Robert's Carb that was epoxy coated and it hasn't shrunk a bit. Also - how's you air filter? Try running it without the filter if you haven't already. If you have one of the old horsehair ones it's pretty difficult to clean. I soaked mine in gas and thought I had it clean but when I tapped it on the concrete floor I still got lots of silt out of it. I had to wash it using a good detergent several times before I got it pretty well cleaned out. When I finally got it clean and ran the tractor it really made a difference. Good Luck.
Dick W
10-09-2003 19:46:35
 Re: D runs! but..... in reply to Jeff, 10-09-2003 19:23:38
It sounds like it's running lean if it's backfiring. Try closing the choke slightly to give it a little more gas to see if that improves running.
Paul from MI
10-09-2003 19:38:07
Sounds like something plugged in the load side of the carb causing a lean mixture at open throttle. I'd try cleaning the carb again, making sure all of the passages are really clean and open.
Paul
