1020 gas for sale
tractorshoppin
10-09-2003 17:59:04
I talked with this guy who has a 67' 1020 gas JD for sale. He does not know the hours. Said it has powersteering, needs paint, good rubber. He has put a carburator kit in it and fixed a hydraulic hose leak. It also has some blowby. I have not seen it yet but he is asking $4500. Would this be worth my while to take a look? Is engine blowby really all that common in these older tractors?
Glen in TX
05-15-2006 08:27:26
 Re: 35 B JD Hand Crank Problems in reply to Jak, 05-15-2006 06:46:45
Didn't say how you were shutting it off? Running it out of gas is the preferred method and not by choking it as that will foul the plugs for the next start. Also might want to check the timing and see where that is.
Glen in TX
05-15-2006 08:20:21
 Re: Parts interchangeability in reply to deereford, 05-14-2006 19:05:44
Also if the number is good or by leaving off the R on end of number you can search the JD parts site at Parts Book section and search Where Used to find applications of that part.
David in Ohio
05-16-2006 15:22:39
 Will No 5 mower fit a 37 B? in reply to deereford, 05-14-2006 19:05:44
Glen in TX
05-15-2006 10:35:06
 Re: JD 30 loader info?? in reply to leinhit, 05-14-2006 12:35:49
Steve, I emailed you some info that should help. Good luck, Glen
Glen in TX
05-15-2006 09:03:47
 Re: slip clutch john deere in reply to scott beasley, 05-15-2006 08:11:54
I guess you tried JD ? Also try dealers for A&I Products or a TISCO dealer for aftermarket. Wants ads & salvage.
Link
aiproducts.com
woodsonline.com (TISCO dealer list)
adeptr.com (parts and state)
Wally Lawrence
05-16-2006 16:26:26
 Re: Re: 2-Cycle Engine Oil Questions in reply to Clooney, 02-22-2003 09:53:17
How do 2 cycle, fuel injected outboard engines lubricate the bearings?
G Childs
05-15-2006 07:21:19
 GP serial # in reply to Clooney, 02-22-2003 09:53:17
Jak
05-15-2006 08:47:55
 Re: 35 B JD Hand Crank Problems in reply to Glen in TX, 05-15-2006 08:27:26
I always run them out of gas.It has a magneto(WICO X),how do you time that?I ran it out of gas then went back to start it and turned the gas on turned it a few times unchoked and no start then I choked it and still no crank then smelled gas.I unchoked it with gas still on and turned and turned with no avail.
Will P
05-15-2006 19:14:14
 Re: G top ring groove problem WMW?? in reply to 1eyedwillie1, 05-15-2006 05:55:46
Sorry, I meant it as what these guys have said. When the piston comes up and compresses the mix. The eye opening in the piston is not lined up with the plug. The plug fires against the piston, and not in the chamber. Making it a dog. After flipping the pistons over, by pulling the rod caps and rolling the piston 180 in the bore. I had this G out with a tandum 10 foot dick pulling it in 4 th gear with ease. But it has blowby. The breather smokes bad. And the fanshaft was walking back and forth grinding the gears in the govenor. Time to take apart.
Will P
Glen in TX
05-16-2006 13:15:58
 Re: Difference Between Standard And Row Crop ? in reply to DAVID BROAD , 05-16-2006 11:39:07
I don't believe all of the smaller 10 and 20 series tractors were offered with standard tread options while larger ones were. Never saw a standard 2510 for example. Larger standard tractors like the 5010, 5020 and 6030 had standard tread options with shorter rear axles, wider rear tire options, HD cast non-adjustable standard tread front axle, wide rear fenders. Standards also had other options like no rockshaft or 3 point hitch, no PTO, and wide swing drawbar instead of regular drawbar setup. Many later 5020s and most 6030s were sold with wider rear axles, adjustable front end axle, 3 point hitch and PTO so the farmer could use them for row cropping also if wanted and gave the dealer options of selling it still for standard dryland wheatland farm use or selling also to a row crop farmer by just changing the tire options of wide or narrow. Only tire options would make the larger standard tractors lower to the ground and I don't recall there being any different gearing options either unless the smaller tractors had that. Some of the others can tell you about the smaller tractors. Never saw any of the larger 30 series on up with standard options except the 6030. Most all 6030s sold in this area were setup with rowcrop axles set for 80" for 40" rows and Hinson cabs with the narrow fenders.
