G FLYWHEEL?
Jonathan
10-09-2003 13:12:37
What kind of wrench do you use to undo the bolts on the flywheel of a G? There doesn't seem to be much room to work with. This G is an electric start.
buickanddeere
10-09-2003 17:52:10
 Re: G FLYWHEEL? in reply to Jonathan, 10-09-2003 13:12:37
3/4" drive socket set, 3/4" drive torque wrench rated to at least 400 ft lbs and a crow's foot socket. Torqueing via by guess and by golly has left flywheels under clamped and loose. Too little and they won't hold. Too much and the bolts stretch, fatigue and loose thier clamping force. New #8 bolts, tall nuts, hardened washers to prevent galling and cam assembly lube on the nuts,washers and threads. Torque to 290 lbs ft in steps of 50 on a 3/4 bolt.
Jack
10-09-2003 13:28:51
There was a special tool for that job but finding one may be interesting.I made me a tool out of an old wrench and a piece of rebar welded to it.Had to use a torch to bend the wrench almost like a horseshoe shape and welding the rebar to the open end of the wrench for leverage.These bolts are tight.Good luck,Jack(TN).
37D
10-09-2003 17:59:07
 Re: Re: G FLYWHEEL? in reply to Jack, 10-09-2003 13:28:51
Don't want to sound like I'm placing an ad, but I have a couple of spare flywheel wrenches, if anyone is interested. They will work on As, Gs,& Ds.
JDHBAG
10-11-2003 14:18:19
 Re: Re: Re: G FLYWHEEL? in reply to 37D, 10-09-2003 17:59:07
I have a 52 A and G and am interested in the flywheel wrenches. Let me know what You want for one. Thanks
37D
10-12-2003 07:45:13
 Re: Re: Re: Re: G FLYWHEEL? in reply to JDHBAG, 10-11-2003 14:18:19
Opps! used the wrong "handle" on the last post, sorry this took so long, been combining corn. If you are still interested, (or go back this far to check!), email me at [email protected]
CMB
10-12-2003 07:40:54
1950 G
10-11-2003 08:41:42
Where are you located? Could you contact me off board, as I have been searching for a wrench for restoring my G. [email protected]
R/
Eric
