Hard starting LA
Dave Mc
10-09-2003 11:03:41
Have a hand crank LA that will not start unless you remove the spark plugs and squirt gas in the cylinders. Once it is running seems to run ok but lacks power.
Dave Mc
10-13-2003 09:55:02
 Re: Hard starting LA in reply to Dave Mc, 10-09-2003 11:03:41
Dwayne and JDM Guy Wanted to thank you both for the feedback it will give me some place to start looking.
Bob
05-15-2006 08:02:46
 Re: Another 12 volt conversion failing JD Model M in reply to moveme, 05-14-2006 17:57:41
You should have an "idiot light", a resistor, or a diode in the lead from the #1 terminal on the alternator to the coil, 'cause if you do get it revved up and charging, without one of the afore mentioned components in that lead, current will feed back from the alternator's #1 terminal to the coil, causing the engine to keep running when the ignition is switched to "OFF".
Third Party Image
Dwayne
10-09-2003 13:27:04
Check your timing, they are very critical on being retarded or advanced a few degris. Your mag should have a good 1/4' blue spark. if not, have it rebuilt. the carb has to be good and clean. wouldn't be a bad idea to have it rebuit also. Is your motor rebuilt or worn out? when you crank it, put your hand over the throat of the carb and see if it has good suction, could be the valves are adjusted too tight and not getting a proper seal. good luck
