JD 530
tom
10-09-2003 10:23:02
When my 530 runs under a load and it get a little hot, it will stop running. If I pull the choke open it will run a liitle longer then shut down. Then it can't be started. Changed plugs, water is ok. Any ideas, carb ????? Thanks in advance, Tom
John VB
11-03-2006 20:29:18
 620 running rough in reply to
Mike Aylward
10-09-2003 19:18:07
 Re: JD 530 in reply to tom, 10-09-2003 10:23:02
Tom, it may be possible that your 530 is vapor locking. Sometimes on my 530 when it has had the guts pulled out of it it will start to boil the gas in the tank because it is so close to the manifold. Common on these tractors. Something to consider. Mike
Wayne in Tn.
10-09-2003 13:53:15
Tom, It could be lots of things, but I would start by replacing the coil. Typically, a coil will do this when it gets hot.
