3 point hitch on 530 John Deere
Dale
10-09-2003 07:57:22
My 3 point hitch drifts down on my 530 John Deere when the tractro is turned off. It comes right back up when it starts. What can I do to stop this?
MIKE HANLEY
10-09-2003 20:27:17
 Re: 3 point hitch on 530 John Deere in reply to Dale, 10-09-2003 07:57:22
You may be looking at alot of labor to replace a couple of dollars "o" ring. My guess is the "o" ring packing on the piston of the rockshaft. Get a parts book and a tect manuel and then hope after you get the seat and the battery box off the battery acid have not eated away the bolts that hold down the cover of the rockshaft. OR if the 3PT is working OK other then lowing when the engine is shut of,,forget about it and lower the 3 PT every time the tractor is shut off. This is realy a good practice to to anyway, as the post below says, the "o" rings and seals are 40 years old. Then if for someother reason you have to go into that area for someother repair, then I would fix it.
rem0h
10-09-2003 13:13:52
isn't this normal - the thing is 40+ years old
