J.D. WIDE FRONT 430
mike
10-08-2003 19:32:33
i want to attach a snow plow to my 430 and was wondering is it appropriate to use the front end slider holes to support the bracket that i would attach to the plow mount and have [2]4x4 angle irons,on each side, attached to it,fastened to the bottom of the bracket bolted to the front end going to the rear of the tractor and bolted fast to take pushing force and put it to the rear of the tractor?? the front end would mainly just hold and support the mount. thanks for any thoughts, mike
440Sam
10-09-2003 17:16:07
 Re: J.D. WIDE FRONT 430 in reply to mike, 10-08-2003 19:32:33
JD made a blade for a 440I that was mounted to the rear axle and supported in the front. The model number of this blade was 301. The 440I was very similar to a 420/430W.
MIKE HANLEY
10-08-2003 22:37:52
Personaly, I would attach to the axels. There is no frame on a 430. Just behind the front wheels bolted just under the tractor and ahead of he axel there is or should be a bracket the the culitvators, or front end weights bolt to. You could use this to mount a piviot point to raise the blade. But you need to put all the push to the rear axels. No place else on a 430 can take the strane other then the axels. Another thing I would throw in here is ,,,we live in Wisconsin and never had a snow storm we could not handle with the rear blade on the 3 PT,,,and the 430 dose have a 3 PT.
