520 power shaft clutch adj.
Rad
10-08-2003 19:00:09
I have a 1957 520 that I'm trying to adj the power shaft clutch. The clutch pedal will not stay engaged.I have made the adj per the operators manual, however,I can't get the indicator rod to adj out "one land and 0.090-inch.
Any help would be appriciated. Also, should the clutch "snap" into place when you engage the clutch pedal? Mine does not. Thanks again.
ChuckW
10-09-2003 11:17:02
 Re: 520 power shaft clutch adj. in reply to Rad, 10-08-2003 19:00:09
the cast iron bracket bolted to drawbar and side of tractor that holds the sway blocks. Located by the lift arms.
ChuckW
10-09-2003 06:07:40
I don't exactly know about the guage. I've always adjusted by snap tension. Remove the right elephant ear, plate over to PTO. Rotate till you see the slot and screw. Tighten screw till it clears then take a large screw driver and ratchet the collar tighter. I believe this is clockwise in observerance. Get it to the necessary tension snapping in, then release and see if you can slip the pto, always use a large pipe wrench, as long as it release good you'll be okay, then realign the screw slot, back the screw up till stops. This should do it...this stuff if not exactly rocket science as all the parts are worn and you have to work with the wear.
Rad
10-11-2003 08:09:02
 Re: Re: 520 power shaft clutch adj. in reply to ChuckW, 10-09-2003 06:07:40
Chuck, thanks for the info. Part of the problem is mine does not "snap" in. No matter how much I adjust, the clutch just gets tighter to engage but never feels like it went "over center" or snaps in. Plus, I have trans oil leaking into pto. I'm one of those guys that found out (the seal was bad)the next day after finding 4 gallons of trans fluid on the floor. How big of a job is to replace the trans seal? Thanks.
Geme
10-09-2003 06:27:47
I have the same problem except my pto clutch is stuck in the engaged position.
what do you mean by the "right elephant ear".
in other words, where do you adjust the clutch.
Gene
