valve lash on Model A 1 valve way off!!, Clooney?
Bill R
10-08-2003 18:24:08
Adjusting the valves today on a Model A and they were all real close, tightened up just a touch, intake valve on belt pulley cylinder was 1/4 inch off! I measured and that valve is coming up just as much as the rest of them, so it doesn't appear to be the valve. Is this uncommon? can i run it with that much of the adjuster out? any ideas?
Bill R
10-09-2003 10:18:41
 Re: valve lash on Model A 1 valve way off!!, Cloo in reply to Bill R, 10-08-2003 18:24:08
Thanks guys, I'll check her over a little more today.
Clooney
10-09-2003 03:41:31
Bill, that 1/4" difference is telling you something, I just don't know what.
~With any luck someone has just replaced a part of the valve train with a part that doesn't match the others.
~If it were me, I would pull the rocker shaft & lay a straight edge across the valve stems to make sure they are all they same height, then compare push rod lengths, & compare adjuster & rocker arm profiles. Maybe the rocker shaft or inside bore of a rocker is worn�.If nothing found by measuring the external parts or valve stem heights you might have cam wear or a bad cam bearing.
~Also roll the engine over & make sure all the valves are opening about the same amount. ~To answer your question...it won't hurt to run it like that, IF it isn't set like that due to a problem somewhere....
Lee
10-08-2003 20:54:08
It will run like that, but not very good. It may have been misadjusted before you got it. But I would double check that once adjusted properly, that valve does have approximately the same 'lift' as the other intake valve, say within 1/10th inch. If it doesn't, it may be a worn cam lobe which would be significantly harder to fix than just a valve adjustment. Coming up to the same height of the other valves is important, so is the amount of 'open' or lift when the cam lobe works the valve. Double check that, and if fine, then you are probably good to go - these old girls can take that kind of abuse and never look back.
