Help where did the oil pressure go Clooney or an
old
01-21-2004 10:15:14
I just started my B for the first time after pulling the oil pump out because of no oil pressure, when it started oil pressure was good but when I throttled it back the oil pressure droped to zero again. Shut it down and checked the oil 1 Qt. low added a Qt. and started it up again still no pressure what in the world is going on. Any body got any ideas????
Clooney
01-21-2004 14:21:58
 Re: Help where did the oil pressure go Clooney o in reply to old, 01-21-2004 10:15:14
Old, you might have broken another coupler if there is water [ice] in the oil or the pump is not spinning free..
~Did you get all the water out of the oil & 1st reduction cover area?... You also MUST use the proper thickness pump cover gasket or the pump gears could bind when the engine heats up a little. If that pump binds it can break the coupler...
[email protected]
old
01-21-2004 15:13:50
 Re: Re: Help where did the oil pressure go Cloon in reply to Clooney , 01-21-2004 14:21:58
Its the coupler and ya I didn't put a gasket in when I put it back togeather, I have all that stuff on order and should have it tomorrow. Then maybe I'll get to more it from the shop to the machine shed with all the others that run
Lloyd ( in CT)
01-21-2004 12:08:32
That may have a coupler as stated earlier,if that breaks,and they do, it will not drive the pump,hence no pressure. Take a look to see that all is connected,also need the gasket in there.Good luck,hope it is easily resolved
Gpower
01-21-2004 10:25:58
Might have to pull off the top crankcase cover and look inside as best you can and look for broken lines, sometimes in the bends going to the mains there can be a hairline crack that when the oil starts to warm, it escapes easier. Also check out your relief valve in the pump assy. and check to see if you can adjust that pressure and see if that helps (not real sure on your model what you would have.)
Gpower
G-MAN
01-21-2004 10:20:13
Broken oil pump drive coupler?
old
01-21-2004 11:12:50
 Re: Re: Help where did the oil pressure go Cloon in reply to G-MAN, 01-21-2004 10:20:13
Broken coupler is what it was. Thanks G-Man I forgot about that. By the way is there shims that go in that pump??? I put it back togeather with silacone so maybe it was in a bind. Well the parts are on order and will get them tomorrow, hope it doesn't do that again I would like to add that to my up and running building instead of my shop so I can start work on my next fix up.
Johan
01-21-2004 11:54:32
 Re: Re: Re: Help where did the oil pressure go C in reply to old, 01-21-2004 11:12:50
You must have a gasket under the pump cover. Silicone is no good! Look in the manual!
old
01-21-2004 12:13:52
 Re: Re: Re: Re: Help where did the oil pressure go in reply to Johan, 01-21-2004 11:54:32
I haven't been able to find one for a B that is that old
