1st oil change........Yow!!
CJDave
10-08-2003 15:12:00
We finally got around to draining the cases on the '52 "A" that we bought and what a mess! This tractor had not been "farmed" or even used for anything but driving a corn auger for well over ten years but had not been left outside....ever. When I took out the pipe plug that was under the transmission, a horizontal fan of brown, low-viscosity stuff, blew all over the place. I drained TEN GALLONS of brown "stuff" out of the gearbox and the book calls for SEVEN. The tractor was leaking black oil and a little brown stuff as well out of the axles. I have NO IDEA where the extra water in the gear oil came from. Luckily, the engine oil was normal; BLACK, but normal; no water or other unusual stuff came out. The filter was almost to the point of disintegrating it was so old. I COULD NOT get the pipe plug out of the primary reduction gearcase to drain it so I had to drill and tap a second plug alongside. The original plug showed signs of SEVERE attempts at multiple unsuccessful removals so rather than weld a nut on it in all the oil that was everywhere under the tractor I just made a new drain. We are real glad that's over and that the engine seems OK.
Ken
10-09-2003 16:57:41
 Re: 1st oil change........Yow!! in reply to CJDave, 10-08-2003 15:12:00
I also have a 52 B. On my recent oil change the stud that holds the cap and thus the filter in place came loose and now just rattles around. Any ideas on how to replace the stud. From what I can see I will have to disassemble the entire engine, removing the block. Any help would be appreciated.
Glen in TX
05-15-2006 08:17:26
 Re: 1950 JD A oil pressure too high in reply to ironhoarder, 05-15-2006 08:04:16
The I&T JD-4 discusses this at about paragraph 120. Get a good oil guage with number readings and see if you have 10-15 psi reading. Adjust the screw where you have that and yes CCW should decrease pressure. If that doesn't work start looking for a plugged filter or obstruction in the oiling system.
tom
10-09-2003 04:33:23
CJDave,
Make sure you flush all the chambers out with some type of solvent [with the exception of the crank-case] to clean all that gunk out. Put the plugs back in, fill with solvent, let soak for a day or two, then drain. Then fill back in with required fluids minus a pint and put in an oil flush to help clean the remaing gunk. That flush will barely thin the tranny and other areas. For the crankcase, you can use a thinner weight oil that can and will gradually break down any gunk, unless you do an engine overhaul. I have heard that loosening up some of that gunk and plugs small passageway that will not get the proper amount of oil. Take the rocker-lid off and see what it looks like in there...I would also remove the oil-pan and clean the gunk-sediment on the bottom there and clean the oil-pump screen was well. Be careful with that screen..
good luck,
tom
CJDave
10-09-2003 06:06:36
 Re: Re: 1st oil change........Yow!! in reply to tom, 10-09-2003 04:33:23
I'm printing out your instructions and adding it to our "tractor" book we are building off this BBS. I'll check with the auto parts and see what they have in the way of a solvent and also the oil flush additive. It's incredible that the cases could build up THREE GALLONS of condensate. The cases must not EVER have been drained. Just peeping in through the filler plug opening, the bull gear looks perfect. Thanks for your responses!!
F-I-T
10-09-2003 06:39:40
 Re: Re: Re: 1st oil change........Yow!! in reply to CJDave, 10-09-2003 06:06:36
CJDave:
Be careful here....if you want to remove the oil pan from your '52 "A", you'll need a torch. Your "A" doesn't have such a thing. If you want to clean the oil pump screen, short of disconnecting and dropping the pump out the bottom, you'll have to remove the top cover over the rods, and try and brush or spray aound the screen to clean it. My weapon of choice has been a cheapie spray/siphon wand to use with my compressor. I start with diesel fuel, put a screened funnel and bucket under the opening, and spray away. The screen in the funnel will catch any big debris for post mortem examination.
On the rearend cleaning, if you don't intend to remove the rear cover, I'd drain the oil and refill with diesel fuel. Drive it around, and spend some time with first one wheel elevated (like in a ditch), then the other. This will slosh out crud in a big way. You can try a second application if you think it's necessary. I've never seen the need to find any special flushing agent, because you'll have just some remnants of diesel in the case, and it has some lubricity and a lot of solvent ability. Refill with the appropriate weight of gear oil for your temperature, and keep the tractor under roof.
On the water in the rear end, I am an unbeliever that the water comes from condensation. First off, the rearend has to get warm and have warm moist air in it. Unless you're pulling something pretty tough, that rearend will hardly ever get warm. I used to pull 3-14's on our '48 "A" in the winter time and the ice and snow melted off the engine, but the rearend keep it's snow and ice all day. Couldn't have been getting very warm.
So then the rear end and it's inside air has to cool (i.e. below the dew point), if it ever did get warm in the first place, and then condense. Those rearends don't vent very well any way, so it would be tough to get the air moving in and out regularly. If the air can't move in and out, there's no way for more moisture to get in.
How, then does the water arrive? Look for rust streaks coming down around the underside of the tranny shift lever boot area as well as the Hi/Lo (not on yours, but on earlier "A"s), and the PTO shift lever. I say that's where the water gets in. It's a moot point, because if there's water in there it came from somewhere, I just have doubted that condensation theory for years. Any tractor we kept under roof kept clean tranny oil, and any one we let set out, the oil got gray.
Frank-in-Tallahassee
70D // 855 // VAC
[email protected]
ironhoarder
05-15-2006 08:04:16
 1950 JD A oil pressure too high in reply to CJDave, 10-09-2003 06:06:36
Rikc
05-15-2006 19:22:11
 Re: JD D ring gear in reply to bw in mo, 05-14-2006 15:20:17
I have a ring gear from an old John Deere that looks unused. just light surface rust. still has some paint on it. I dont know what it fits but it is bigger than the ones on my B and 520. If you can give me some measurement I can check.
Rick
Bill R
10-08-2003 18:33:01
Not uncommon what you say about the rearend oil. water comes from condensation inside the housing
