730 tranny problem
Karl
10-08-2003 09:22:40
It all started when my tranny got stuck in 2 gears and would not move. I was a waze from the house so I kept messing with it untill I got it out. Now my tractor has a clunking sound in 3rd and 6th gear about every revolution of the tire. I was wondering how big a job this would be to fix. Thanks for any info.
Clooney
10-08-2003 10:14:48
 Re: 730 tranny problem in reply to Karl, 10-08-2003 09:22:40
Karl, that sounds like something in the bull gears or axle bearings. It doesn't sound like the trans as most trans parts spin faster than once per rev wheel speed.
~Maybe you bent a shift fork or shift rail & it is rubbing one of the bull gears.
~In any case start by applying each rear brake [with the tractor moving] to see if you might have a tooth problem on a bull gear & if that doesn't show you anything you will have to pull the trans top cover & look for contact inside the trans area..
~If you applied too much engine power with it stuck in 2 gears at once you might also have bent a trans shaft...I hope not as that usually means a complete trans disassembly�
