3020 capacities
Randy
10-08-2003 06:43:02
I am wondering if anyone knows of a website where I can find a page that I can print out that has capacities, specs., ect for a gas 3020 JD. I tried my local dealer and he says they do not have such a page. I did order a manual, but it will not be in for some time and I would like to do some maintenance. You can email if you would like.
thank
Randy
G-MAN
10-08-2003 07:38:41
 Re: 3020 capacities in reply to Randy, 10-08-2003 06:43:02
Exactly what info are you looking for? All of the various specs and capacities are right in the service manual, and I have one here, but it would be fairly time consuming to type in everything. If you would give me some specifics, I could help you out.
Randy
10-08-2003 08:04:37
 Re: Re: 3020 capacities in reply to G-MAN, 10-08-2003 07:38:41
Mainly the fluid capacities(water, oil, hyd. oil) plug gaps, points gap, carb settings.
thanks
G-MAN
10-08-2003 10:04:18
 Re: Re: Re: 3020 capacities in reply to Randy , 10-08-2003 08:04:37
Okay, here's some basics for you. Hydraulic capacity (includes transmission) -- synchro-range - 11 gallons initial fill/8 gallons at service (as you won't get all the oil out doing a normal drain) -- powershift - 14 gallons/11 gallons at service. Engine oil -- 8 quarts w/filter/7 quarts w/o filter. Cooling system -- 19 quarts. Plug gap -- .025". Breaker points -- .022" (31 to 34 degrees dwell). Carb mixture screw -- Marvel-Schebler - 2 1/4 turns/Zenith - 1 3/4 turns. Both are just starting points, and further adjustments are probably required.
Russ
10-08-2003 16:05:49
 Re: Re: Re: Re: 3020 capacities in reply to G-MAN, 10-08-2003 10:04:18
3020; A few more spec's; I.E.,1972, 4cyl, 241CID gas, xmsn 8F-2R, 71hp, and 7420 lbs. If you can
still reclaim the original 71 hp you have got yourself a decent beast. Good luck in receiving the JD 3020 Repair manual. Have a blast reconditioning this old but faithful tractor.
