Constant Problems on old 60
Doug McKinley
10-07-2003 20:07:40
I have what I believe to be an 1953 Model 60 JD. I inherited it about two years ago. Since then I have replaced Generator, starter, distributer & carberator. I myself have not performed these tasks but my friendly neighbor farmer has. Still I have very frequent problems with getting her started and staying running. The distributor is 3months old and yesterday had to file down the point to get her going. I will be about an hour into mowing and she'll start back-firing. I was told to put ATF fluid into the fuel to help break up carbon deposits on the valves. This will work for a while than it's right back to problems. My Question to all of you is (Drum Roll) 1. Is this comman in a tractor this old? 2. Should the motor be rebuilt perhaps? or is it more cost prohibitive to try and find an older tractor already rebuilt? 3. How can I find someone in the Northern Indiana area to work on it (Not a dealer)? I would appreciate any suggestions and advice.
Doug McKinley
10-08-2003 08:51:22
 Re: Constant Problems on old 60 in reply to Doug McKinley, 10-07-2003 20:07:40
Gentelmen, thank you for your suggestions and comments. You are correct, I did not put much information into my comments. This is my first time on this site and was concerned that if I gave to much, I would not receive any feedback. Here is some more: 1. During the running of the tractor, it seems to act up the most when it's under a heavier load. Even when I make sharp turns it will start backfiring like it is loading up. 2. I have noticed that I have green fluid laying on top in the recessed journals on the engine block where the block mounts to something. I assume these two recessed journals are for being able to get the wrench onto the two bolts that are sticking out. My tractor sits in a metal shed and I first thought that this might be condensation, but then why is it green? From the Paint maybe? I know it's not gas leaking down from the tank. 3. When I open up the radiator cap after running for an hour, I see a lot of foam on top of the coolant. Does this indicate a blown head gasket? Is my pump not pumping?
JDVan
10-08-2003 13:17:47
 Re: Re: Constant Problems on old 60 in reply to Doug McKinley, 10-08-2003 08:51:22
Green Fluid indicates Antifreeze. Check for leaking gasket between block and main case or at upper water pipe where it connects to block. Check for bubbles in the radiator when running with the cap off. Perform a compression check when hot. Absolute value not as important as being similar between cylinders. Try retorquing the head bolts or temprarily adding some radiator sealer and see what happens.
F-I-T
10-08-2003 13:52:33
 Re: Re: Re: Constant Problems on old 60 in reply to JDVan, 10-08-2003 13:17:47
JDVan:
The gasket between the block and the main case seals off oil only. The back of the block is solid so if it's leaking antifreeze there, he's got a major problem, ala crack. Look for a seep at the upper water pipe connection. Closest place for coolant to come from.
Also, do you have any crud in the tank. I had an "A" that had debris in the fuel tank and it would only actup during turns.
Frank
Clooney
10-08-2003 03:55:27
Doug, you didn't give us much to go on so this will have to be kind of general.
~If that points filing is a frequent ritual then I have to agree with Mike on a possible coil problem.
~Next time it starts to act up place your hand on the ignition coil & see if it is getting hot. If it's too hot to touch you probably have the incorrect coil for your tractor. The early Deere 60 tractor didn't use a ballast resistor & if someone has installed a later 6 volt type coil on you tractor it will cause you all kinds of grief.
~Signs of an incorrect coil will be stating good then quitting [or running poorly] after a short while of running. You will also get frequent points burning & turning blue.
~Seeing as you are having someone else do your mechanical work I don�t know how involved you want to get yourself. If you have an ohmmeter & know how to read it you can measure the resistance between the 2 small terminals on your coil & if below 2 ohms you have the wrong coil. You need a coil with an internal resistor & that will be over 3 ohms between the 2 small terminals. You also have the option of removing the coil & taking it to your local auto parts store as most auto parts stores have the meters & know how to measure the coil�s resistance.
~Next on the list would be the proper fuel flow TO & THROUGH the carb. To check that, open the carb drain on the bottom of the carb & make sure you have a pencil sized stream of fuel flowing out for AT LEAST 30 seconds [Note: if you have an oil pressure controlled fuel shut-off you will have to unscrew the knurled knob on it�s top & hold it down to allow fuel to flow]. If you aren�t getting a good fuel flow you have probably found the problem & will have to check the carb strainer & strainer at the fuel tank for restrictions.
~If you pass the fuel flow test then you have to do some other basic tests like compression, valve lash, & ignition system voltage tests.
~On the ATF in the fuel�.I don�t recommend that as there many additives in the ATF for transmission clutch friction enhancement & those don�t burn worth a darn. Instead use some 2-cycle oil or top end oil like Marvel Mystery Oil.
~You might want to look in the archives [at the top of this page] & do a key word search. Problem is the key word doesn�t like multiple words so if you have a lot of reading time just put in Clooney or WTW or John T, problem is John T will bring up ALL the Johns that have ever posted.
~Feel free to post back with any questions or how to�s on any of the tests you want to run. Or just E-Mail..
~The more precise the symptoms you can describe & the more detail you can provide on how & when your tractor acts up the closer we can get on the answers to your running problems�.
~Those 60�s a great running tractor & yours should run like a top when it set up correctly..
[email protected]
tom
10-08-2003 07:05:15
 Re: Re: Constant Problems on old 60 in reply to Clooney , 10-08-2003 03:55:27
Hi Clooney,
Starting to really understand the posts now...thanks to you and all. However, what is a valve lash test and what do you do to perform the diagnosis?
thanks,
tom
Clooney
10-08-2003 10:19:52
 Re: Re: Re: Constant Problems on old 60 in reply to tom, 10-08-2003 07:05:15
Tom, a valve lash test is simply running the tractor until hot then removing the valve cover & bringing each respective cylinder to TDC [compression] then shaking the rocker arms to see if there is still some valve lash. [basically making sure on a hot engine the valve lash isn't set too tight & holding a valve open]�
mike
10-07-2003 22:46:35
doug first off 60s a good tractor it sounds like maybe it is the wrong ign.coil I.E wrong voltage which is causing burnt points not common been running mine on same points for 5+years have to clean every spring when it sits then runs great that would be my first guess though good luck and keep posted mike
