720 diesel oil choice
Jake
10-07-2003 19:22:07
In teh 720 Diesel the op. manual calls for 10w30 SAE. Thats what I have used in past but it does not specify specifically diesel engines in fact it only references gas engines. There is a "diesel engine oil" at Walmart called SAE 30 and SAE 15w40.
Would there be a better chioce than 10w30 now a days? I am in warm summer, very cold winter climate.
Clooney
10-08-2003 04:10:39
 Re: 720 diesel oil choice in reply to Jake, 10-07-2003 19:22:07
Jake, you asked a valid question. ~A lot depends on how hard you use your diesel tractor. If just light duty & parade type playing any of the multi-weight oils will be fine. If you work it hard then you should really use a diesel rated oil.
~Here is pretty much the deal on engine oils...Diesels have a lot of internal friction due to the high compression & injection parts running on the camshaft. Most diesel rated engine oils have a pretty high concentration of sulfur in them to fight that higher internal friction. On the other hand most of the newer gasoline engine rated oils have had the sulfur removed because of emission requirements. Catalytic converters & oxygen sensors don�t handle the sulfur very good.
~While there many fine diesel rated oils out there my personal choice is the Shell Rotella T in either straight 30 weight for some of my summer only tractors & 15W40 for my all weather tractors. ~Whatever oil you decide on remember the less spread between the high & low number in a multi-weight oil the more lubricating ability & the less filler. SO, 10W30 is actually a better lubricating oil than 10W40. You are pretty well stuck with a 15W40 for most of the diesel rated oils though�.
[email protected]
Tyler-MO
10-08-2003 06:38:46
 Re: Re: 720 diesel oil choice in reply to Clooney , 10-08-2003 04:10:39
Clooney,
I've been thinking of using John Deere Brand instead of Farmland Oil that I buy from the local Co-op. Do you have any technical information to pass to me as far as 15w-40 or 30wt Deere oil is concerned? My dad used rotella in our 7.3 Ford and now in our 6.0 Diesel Ford truck and have had great luck. Also, I know it's been awhile but do you still have that spec. list for the 520 LP? Thanks for the ideas and opinion
Tyler in Missouri
Henry J
10-08-2003 03:10:25
Jake
While you are shopping there at Wall Mart, they should also stock Shell Rotella. Take a look at that stuff. I have run it in my Powerstroke for years. We all know that times have changed big time with lubricants since ther era of the early diesels.
A neighbor uses the 15W40 stuff from John Deere in all of his implements from the ole retired antique tractors to the new bread winners and combines. He has a grain truck which I think is about a 72 International gasser that he uses the JD diesel oil in. Last fall he ran it hot and toasted the top end (cracked the heads). I helped him do the rebuild and noticed that the inside of that motor was cleaner than the last hospital I was in.
I try not to go on the theory that it has to cost a lot to be good, but motor oil is one thing that I won't take a chance on unless maybe I saw the wall mart jugs being filled out of the Rotella Vat.
Anyway, my thoughts on diesel oil. Have Fun!
MIKE HANLEY
10-07-2003 22:19:37
We have used FARM OYL brand GP-3 30# in everything for 30 years. Well everything except the transmissions (90#) and the power steering (John Deere PS fluid). We use the GP-3 30# in the engines, hyds, and PTO's of the 430 crawler, the 630, both 730D's and in the engine of a 1946 WILLIS Cj-2A JEEP. Two things here. Even if you don't use the tractor enough to meet the hours on the recomended oil change as stated in the ops manuel, I would still change all the oils Hyds, PTO transmission, power steering and engine spring and fall. If you have fog in the morning so that you have to turn on the wipers, or scrape frost in the winter, you will have moisture in your oil. The other thing is yes we use 30# in the winter but we try and never start a cold engine. Below 32 degrees we plug in the tank heaters on what we will be using that day. That way we only have to have one oil on the place and there is no question as to what oil goes where. Then we buy 90# and power steering fluid for the changes. For a record for the warranty we have the truck's oil changed in town. The car is way past warranty, but the wife stiil has that changed in town. One other thing while I'm on oil. I have read that there has been some lawsuits and warranty problems on new least tractors where they were hooked to a piece of equipment that had a remote cylinder that was just also on an old tractor and cross contaminated the new tractor's oil with a weight of oil not reommened for the new tractor hyds. Weather there is anything to it or if it's just a few cases of finger pointing to place blame somewhere,,,I do not know, but it is something to keep in mind.
