1941 hand crank for a starter type 41
dave compton
10-07-2003 18:02:18
hi im looking for a picture of a crank for a 1941 jd that fits in to flywheel it has a starter but i am looking for a crank. any imfomation please email me
jdman(MO)
10-07-2003 19:56:23
 Re: 1941 hand crank for a starter type 41 in reply to dave compton, 10-07-2003 18:02:18
Think that would be a AA3032 R cranking shaft shown on page 35 of the parts book for the Model B.Russ
JD-Tractor
10-07-2003 18:57:14
Didn't actually have a crank but had a little piece that your steering wheel went onto that went through the flywheel coner to turn the flywheel !!!
RJ-Az
10-07-2003 19:26:45
 Re: Re: 1941 hand crank for a starter type 41 in reply to JD-Tractor, 10-07-2003 18:57:14
Thats the only one I've seen that goes in the steering wheel. Same diameter as the steering shaft and about 2 to 4 inches long with about a 1/4" or bigger crosspin. But i haven't been around one since 1964.
jdman(MO)
10-07-2003 21:43:02
 Re: Re: Re: 1941 hand crank for a starter type 41 in reply to RJ-Az, 10-07-2003 19:26:45
Looks like there are 2, one for the older tractors has the cross pin and the one for 1947 and up has a slot cut in the end. Russ
jdman(MO)
10-07-2003 21:49:57
 Re: Re: Re: Re: 1941 hand crank for a starter type in reply to jdman(MO), 10-07-2003 21:43:02
A little post script on this great John Deere invention. First, you removed the steering wheel by using a cresent wrench, then a good rap with a hammer, insert the cranking shaft, then insert in the flywheel hole. I can tell you it did not have the secure feel that a handstart flywheel did but did work. This tool was in the toolbox of each starter equipped tractor, at least in the early 40's. Russ
dave
10-08-2003 07:57:16
 Re: Re: Re: Re: Re: 1941 hand crank for a starter in reply to jdman(MO), 10-07-2003 21:49:57
jd man u have a picture of it?
jdman(MO)
10-08-2003 08:26:43
 Re: Re: Re: Re: Re: Re: 1941 hand crank for a star in reply to dave, 10-08-2003 07:57:16
E-mail me at [email protected] Russ
dave
10-08-2003 07:52:09
thanks guys i know what to look for now or how to make it
