How to get those rusty lift arms apart on 801 hitc
Will
01-21-2004 08:38:07
I have been in the process of sand blasting and painting my 801 lift hitch. I have gotten everything operating and painted except the lift arms. I got the pins out, but the arms wont come apart. They have been soaking in waste oil and diesel fuel for about a month. I have heated them several times with no success getting them apart. Does anybody have a secret, or has anyone else had this problem? Thanks for the help!!
Joe P.
01-22-2004 05:25:05
 Re: How to get those rusty lift arms apart on 801 in reply to Will, 01-21-2004 08:38:07
Why do you want to get them apart?
JDVan
01-21-2004 10:12:38
We may have a terminolgy issue to deal with here. Are you talking about the two lower draft arms that are supposed to slide in and out or the threaded lift links? I'm going to assume you are asking about the lower two draft links. A common acetylene torch setup typically doesn't offer enough heat to adequately heat all of these arms to get them to slide apart. I have had success with a torch on the threaded screws but not on the two lower draft arms. In a failed attempt one time I hooked a 60 and 620 back to back connecting a draft arm between the two with 4 twisted clevises and then heating as much as I could with a torch while tugging on it with one tractor. Failed completly but drug the 60 with locked brakes several feet.
The only way I have had success is the method Duane mentions by inserting the draft links into a forge and getting them completely red hot and then letting them cool, several times. Then it still may take some heavy tugging and pounding. An alternate is to use a bed of BBQ coals and bury the draft link in the coals and let it heat with a fan to blow on the coals. It takes an enormous amount of heat. Way more than what can be achieved with a normal acetylene setup. The amazing part is when they do come apart and are cleaned up they rattle around inside the square tubes.
will
01-21-2004 10:23:33
 Re: Re: How to get those rusty lift arms apart on in reply to JDVan, 01-21-2004 10:12:38
Yes I am talking about the lower lift ARMS not threaded lift LINK. I never thought of a bed of coals, but I have the perfect thing. My out-door wood furnace! Ill put them in there and get them nice and warm. It will be 2 weeks before I go home from school, and I will try it then, and let you all know how I come out. Thanks to allfor the suggestions.
Andy from IL
01-21-2004 09:07:46
I use a torch to heat them and use a come-along to keep tension on them until I get them apart. Like you I had soaked them in oil, I recommend (PB Blast). I have had some success Without heating using the come-along method and PB Blast but if all else falls go ahead and use the heat. Just make sure what you are using for stationary points to hook your come-along to will not break as it make take quite some pulling to get them apart.
Duane Larson
01-21-2004 08:45:09
Will,
I have a blacksmith friend who regularly separates 3 point arms. He has a gas forge, cylindrical, about 12" dia and 24" long, that he sticks the arms in and gets the whole unit red hot. He then puts one end in a vice and a pipe wrench on the other end and they screw right out. So, if you can find someone with a forge, it will work.
I asked the blacksmith about any loss of strength during the heating/cooling process and he did not believe it was a problem.
