JD 50 differential bearing housing gaskets needed.
Bruce L
10-07-2003 12:28:46
For the JD 50, the differential bearing housing gaskets are no longer available from John deere on the non-shimmed side. Thin paper gaskets can still be obtained for the side that takes the metal shims. Does anyone know of an alternative source for this gasket. I have a feeling I'll be trying to make one.
Bruce L
10-08-2003 11:01:48
 Re: JD 50 differential bearing housing gaskets nee in reply to Bruce L, 10-07-2003 12:28:46
Thanks for your comments both Dave and Frank. I had to get a lot further into this 50 transmission than I ever planned. But it is going back together nicely and I am feeling good about all new bearings. At some previous time, the spring that puts pressure on the detent for the PTO shifter shaft broke into three pieces. That caused some jamming of the shifter shaft. Because the shifter shaft was partially jammed, I assume some unknown previous operator twisted the PTO driveline disengagement hard enough overcome the snap ring that holds the spool on the shaft. The spool slid off the shaft and went through the transmission gears. It was chewed up into four pieces. Surprisingly there were no broken gears. I found that all the bearings had corrosion damage of various amounts. In spite of the extra repair cost, I have enjoyed overcoming the challenge of a transmission rebuild and would never again consider a tractor "restored" unless the transmission had been at least been opened up and thouroughly inspected.
F-I-T
10-08-2003 11:57:53
 Re: Re: JD 50 differential bearing housing gaskets in reply to Bruce L, 10-08-2003 11:01:48
Bruce:
Glad to hear that you're getting it back together. I've always thought that a bearing was a pretty good value, given all the work that is in one. But I just got finished replacing all the ball and tapered bearings in my little VAC transmission, torque tube, final drive and axles, and it ran over $600.00! I was a bit surprised at that cost.
Good luck!
F-I-T
DaveH 50
10-08-2003 05:37:23
Bruce,
You'll probably have to make that gasket ( B3086R ). It's not available from Deere. When I rebuilt the transmission in my 50 this past June I called around to several places that advertise having lots of NOS parts. That gasket is one that it seems nobody has. Making your own gaskets is actually pretty easy. If your can trace the piece on the gasket stock you can cut it out with scissors, utiity knife, or an Exato hobby knife. Another way is to use a small ballpeen hammer. First cut the outside of the gasket with scissors. Then lay it on the transmission case where it goes. Hold it firmly in place and take the rounded end of the hammer and carefully peck at it at all of the holes. If done carefully there's no damage done to the part and you'll have nice clean edges on all of the holes. I've been through my 50 from front toback this summer. I got pretty good at making my own gaskets when one wasn't available or I forgot to order one and didn't want to wait 1 1/2 weeks for it.
Good luck, Dave
F-I-T
10-08-2003 08:48:18
 Re: Re: JD 50 differential bearing housing gaskets in reply to DaveH 50, 10-08-2003 05:37:23
Dave's right on. I bought two sets of gasket punches on EBay for under $10, including shipping (they came two for one!?!).
I've been making most of my simple gaskets for my little Case VAC, and the ball peen hammer trick makes for a pretty nice gasket. I even tap around the outside instead of scissor trimming if I can. I just tap enough in the holes to get an outline, and then use the punch to clear the holes. I have an old cutting board I use for the gasket punching and cutting.
NAPA has a good selection of gasket papers, though you can also use all sorts of card stock you accumulate around the house. Years ago, I made alot of paper shims out of paper grocery sacks. Somewhere in Ohio, 3 or 4 people are probably wondering why it says "Kroger" or "IGA" on their gaskets!
Frank
