Early Styled Manifold Gasket
KrisA
10-07-2003 10:05:10
Hey there gentleman I was wondering if anyone could provide me with a supplier to get the manifold gastket and 2 manifold bolts, other than JD itself. I would appreciate the help. My usual supplier is having troubles finding these items. Thanks
KrisA NC
G-MAN
10-07-2003 10:36:31
 Re: Early Styled Manifold Gasket in reply to KrisA, 10-07-2003 10:05:10
For which tractor? What's wrong with getting them from Deere? Most gaskets are still available for just about all the old two-cylinders, although some of them only come in kits. If it's an issue of price, I think you'll find that in many cases, Deere is actually CHEAPER than aftermarket. I remember reading about a gasket kit for an "A" than an aftermarket company was selling for over $100. The same set was available through Deere for around $40. I looked up the manifold gaskets for the unstyled "A" and "B". There are two listed for the "A", and one listed for the "B". They are all still available, and none costs over $7. If you give me a model and serial number, I can provide you with a part number, and your local dealer should have them overnight. I fully understand shopping for price, but a lot of people seem to overlook or ignore what to me is the most common-sense place to look for Deere parts - a Deere dealer. Particularly for something so cheap as a gasket.
KrisA
10-07-2003 10:48:20
 Re: Re: Early Styled Manifold Gasket in reply to G-MAN, 10-07-2003 10:36:31
Sorry I am looking for a '46 B. I asked for others beside deere because I don't have a deere dealership near me! Thanks for the info G-Man.
G-MAN
10-07-2003 10:50:40
 Re: Re: Re: Early Styled Manifold Gasket in reply to KrisA, 10-07-2003 10:48:20
I'm sorry, I screwed up and thought you were looking for unstyled parts, although the styled gaskets are also still available. In the absence of a Deere dealer, you might try a local auto parts store or machine shop. They can probably get you a gasket, but you may have to buy an entire valve-grind kit or something like that to get it, depending on how they're available. Sorry about the mix-up.
KrisA
10-07-2003 10:59:10
 Re: Re: Re: Re: Early Styled Manifold Gasket in reply to G-MAN, 10-07-2003 10:50:40
Not a problem I appreciate your help anyway!! Thanks
KrisA
Clooney
10-07-2003 11:19:48
 Re: Re: Re: Re: Re: Early Styled Manifold Gasket in reply to KrisA, 10-07-2003 10:59:10
Kris, just a thought� If you have a credit card, most Deere dealers will UPS parts to you over the phone. I do it all the time when I use the dealer locator to find a discontinued part. There is usually a small charge but in most cases it is cheaper than the drive..
F-I-T
10-07-2003 17:00:08
 Re: Re: Re: Re: Re: Re: Early Styled Manifold Gask in reply to Clooney , 10-07-2003 11:19:48
On top of UPS from a dealer, can't you set up an account through JDParts.com and get parts shipped direct? I haven't done that yet, but have been considering it. I have, BTW, ordered some parts from a Case-IH dealer on the web, and they showed up at my door just fine.
F-I-T
