4010 slow 146 loader
Wolfie
10-07-2003 06:36:49
I have a John Deere 4010 diecel with a 146 JOHN Deere loader. The question I have is after the tractor sits over night. I start it up I raise the loader it is real slow to go up and shakes a bit as it goes up. It takes about a Min. after warm up to get the loader to raise up with out shaking. Someone told me not to use the clutch. I tryied that but seems to be the same. Is this a common problem or is something else going wrong. I have no 3pt. if it matters and I use the 2 levers on the tractor to raise a dump the bucket.
Wolfie
chris
10-07-2003 20:41:37
 Re: 4010 slow 146 loader in reply to Wolfie, 10-07-2003 06:36:49
Wolfie, go to your JD dealer and ask for the check valve kit to stop your problem. The check valve goes in the elbow fitting that is connected to the suction line of the front pump(elbow is by the filter and screen plug). There is an internal check valve that goes bad and this is a fix without tearing your tractor apart. The part number is something like L70146. It's a check valve for the front pump on utility tractors. There is a service bulletin that tells how to do it, by drilling and tapping threads into the elbow and installing the check valve. If you have problems finding this email back. chris
G-MAN
10-07-2003 10:42:08
That's a fairly common problem on the older tractors. The hydraulic system is basically just losing it's prime. As the tractor sits overnight, the hydraulic oil is basically draining back into the reservoir. The transmission pump, located back in the differential housing, pulls the oil out of the sump (the housing), and then sends it to the main pump, which supplies oil to the hydraulic functions. The tranny pump doesn't run unless the clutch is engage, which is why someone suggested not using the clutch. I'd suggest checking and cleaning the suction screen, and maybe replacing the filter. That may speed it up some. If the system works fine after the initial problem at start-up, it's probably not worth tearing into to find a potential problem, unless you have extra time and money to spend.
Wolfie
10-07-2003 11:04:44
 Re: Re: 4010 slow 146 loader in reply to G-MAN, 10-07-2003 10:42:08
Thanks G-MAN You have helped me in the past.As it is I already have a few bucks stuck in this 4010. I will change the filter and clean the screen. Should be in the repair manual how do it right.
Wolfie
G-MAN
10-07-2003 13:32:21
 Re: Re: Re: 4010 slow 146 loader in reply to Wolfie, 10-07-2003 11:04:44
Yes, it should be in both the repair manual and the operator's manual. If you're going to the dealer to get an new filter, pick up a new sump screen while you're there, and a new sealing washer for the plug that keeps it in. The sump screens are cheap, and it's just easier to slap a new one in than screw around and clean up the old one. You'll have to drain the oil to do the sump screen, so it's not a bad time to just replace it. Shouldn't take more than ten gallons at the max, and your tractor will love you for it, particularly if it's been a while since the last change. Even fresh hydraulic oil might help your problem a little. Glad I could help.
