40JD
D. Overly
01-21-2004 07:48:46
I would like to see if anyone as a wiring diagram for the 40JD #60310.
Thanks
Clooney
01-21-2004 08:55:07
 Re: 40JD in reply to D. Overly, 01-21-2004 07:48:46
D. Overly, post or send me an E-Mail.. Put "40 wire diagram" in the subject line so I can find it.. I will then E-Mail you back a 40 wire diagram..
~The 40 is considerably different than the M as it uses a voltage regulator & different generator & light switch wiring..
~Also let me know what type 40 you are working with as the wire diagram varies a little due to model type...
[email protected]
tom
01-22-2004 01:34:53
 Re: Re: 40JD in reply to Clooney , 01-21-2004 08:55:07
D overly,
my apologies, clooney is right...it is the engine that is basically the same with also a dual TOM and many similarites...
tom
01-21-2004 08:09:54
D. Overly,
post your e-mail address and i can send you a color-coded with correct gauges wiring diagram of the M series, which is 98% the same as the 40...
tom
