Off Topic but Desperate!
Bassman
10-06-2003 21:52:26
I've spent countless hours reading the questions and responses on this web site and it never ceases to amaze me the amount of knowledge contained within. So, while this is off topic, I figured if I could get a straight answer it would be here:
I had a pond dug out last winter, it had filled with silt over the years. We finally got enough rain over Labor Day weekend to fill it, but now I find the overflow tube is leaking. It has a four foot vertical tube connected to a 3 foot horizontal tube. The four foot tube is leaking around the rivets and the three foot tube is leaking at a seem several feet inside the opening. Short of digging the old tube out and replacing it, is there a way to seal the tube from inside?
I know this is way off the topic of tractors, but like I said, if anyone would know the answer you guys would!
John
10-07-2003 03:47:00
 Re: Off Topic but Desperate! in reply to Bassman, 10-06-2003 21:52:26
If you dont need all of the flow capacity of the 3 foot tube you mite consider slipping a smaller pipe inside of it. Cut the hole for the vertical tube and drop the vertical piece to meet it. Then concrete the the gap between all to make it permanent. Maybe you can also dig in a new pipe elswhere while the old one is still in place.
Pete/ME
10-07-2003 03:41:04
How about shoving one of those black plastic culverts down the verticle pipe?
