4320 runs great but engine stops after about 5 min
modelbjd
10-06-2003 20:12:46
My 4320 will start again after about 5 minutes then quits after about 3 - 5 minutes. When running it has full power and runs great! What's up with this? It seems in colder weather it will run longer.
Jer
10-07-2003 20:09:18
 Re: 4320 runs great but engine stops after about 5 in reply to modelbjd, 10-06-2003 20:12:46
Check to see if the return line is clogged. Unhook it from the injection pump and then see if it stays running. If so you need to take off the line and blow it out with air pressure.
tom
10-07-2003 04:14:47
Change out the coil...when the coil gets hot, it stops...the reason it runs a little longer in the cold is because the coil is cooled somewhat and takes a little longer to heat-up...change the coil.
Mike w J
10-06-2003 21:52:41
It has an electric shut off coil that gets hot and then shuts the fuel off it has 2 wires going to the top of the injection pump the top of the pump comes off with 4 screws its an easy change but I think its about 80 bucks
