G-MAN
10-07-2003 18:28:59
Re: Re: Re: Re: Re: 4440 Help! in reply to Ray, 10-07-2003 17:16:50
Over-revving can cause a piston to hit a valve when the valve springs can't keep the lifters "stuck" to the cam lobes. As the cam turns faster, the lifters "jump" off the backside of the lobe, which allows the piston to hit the valve, because it isn't on it's seat as the piston comes up. I've never seen this happen on a Deere personally, but I imagine it could. However, you'd think that the piston would do no more than knock the valve back onto it's seat where it belongs, as the cam wouldn't be stopping it. I would think that the engine would have to be overrevved to the extreme for this to happen, because I've seen "turned up" farm-stock Deeres turn up to or a little over 3000 rpm without breaking a rocker arm. I guess it would depend on how weak the valve springs are. If the cam gear slipped far enough, that could cause this to happen, but like I posted, your timing would also be affected, and the engine would run very poorly, so you'd know something was up. The easy way to check it is by checking injection pump timing. If it's out of time, and there isn't enough play in the injection pump drive gear slots to allow you to correctly re-time it, it's a safe bet that the cam gear slips. It's a very rare occurence, as in four years of turning wrenches on Deeres, I've only seen one cam gear slip. At any rate, be it a warped head OR overspeeding, it will be readily apparent upon removing the head, as the tops of the pistons will show evidence of hitting the valves, if that is the problem.
