2020 - steering too much free play ?
JohnE from Sout
10-06-2003 17:45:35
I have a 1967 (serial#050xxx) 2020 gas with power steering. There is about 80 degrees of free play in the steering somewhere in the "column"(between the steering wheel and the beginning of the steering linkage underneath). (If you are turning in one direction you have to turn the steering wheel about 80 to 90 degrees before you (or the front wheels) start to turn in the other direction.) Is it supposed to be this way? Fixable by an amateur? or should I take it to a professional(dealer)? or live with it? Thanks for your time & help.
david val
10-07-2003 00:03:37
 Re: 2020 - steering too much free play ? in reply to JohnE from SouthernOH, 10-06-2003 17:45:35
what kind of power steering? open center (with the pump on the timing cover) or closed center?
david
JohnE from Southern OH
10-07-2003 14:30:56
 Re: Re: 2020 - steering too much free play ? in reply to david val, 10-07-2003 00:03:37
The book says it is a "Closed Center-Type" Power Steering (serial# 45200 and up}. This "Free Play" exists whether the engine is on or off.
