830 mud behind fenders plowing
robert
10-06-2003 16:53:29
How did they do it 40 yrs ago? the dirt packs tight in behind fender,furrow side rear(18.4-34).Can't move wheel out as front axle is non-adjustable.pullin 5-14 666h.will 2 of these plows hooked together and an onland hitch make it all better to get both wheels up onland?or will one be known as a show-off??
JohnDeere_John
10-08-2003 17:32:32
 Re: 830 mud behind fenders plowing in reply to robert, 10-06-2003 16:53:29
I have a 830 pulling a 5-16 in gumbo and have no problem. Sounds like your trying to plow when its two wet. The front wheel width can be changed by turning the wheel around and using the dish to make a difference. There is no adjustment on the fenders
John
10-07-2003 19:06:37
Take A look and see if you can adjust your fender toward the center A little. My opinion though if you are getting that much packed up, you probably need to let it dry out a little before plowing.
