Gary: Sorry I misunderstood. I thought you had everything loose but the pinion shaft. If the tractor is still under power, you might take it out for a spin like others have suggested. Kicking a brake can't hurt, and running it in a ditch where it can have some sideways force will help. Take a wrench along so you can snug it back up if it breaks free. Keep the three wedge retaining bolts in loose, but close enough to seated so that if it pops loose the wedge won't jump out. While the wedges are tough to get loose, they will usually give in way before the pinion shaft. Getting that to move is quite another story. The second method to move the wedge is to thread the three bolts into the wedge and then back them off just a 1/2 turn. Give each of them a whack with a convincing hammer. This should pop the wedge loose. I used my impact wrench on the two jack bolts the last time, and let it hammer for a good 1 1/2-3minutes at a time. As I impacted it, I swung a three pound sledge on the head of the three bolts and it popped off after about 2 minutes. Be prepared to replace the three bolts of you beat them up (I had a tap and die so I cleaned up the heads and the threads). I don't like beating on the axles if I can help it. Bought too many of those Timken bearings over the years (just got done putting over $600 worth in my VAC Case!).
Good Luck! Frank
