Fuel Gage
Earl
10-06-2003 04:03:08
Anyone know a quick way to check my fuel gage on my 2240 to determine if it is defective? The sending unit at the tank appears new; however, the fuel gage shows only about a quarter full when the fuel tank is full. I removed the sending unit at the tank to make sure it was installed properly(not upside down or 90 degrees off), so I am making the assumption the sending unit "may" be defective. Thanks in advance!
frank
10-06-2003 18:08:03
 Re: Fuel Gage in reply to Earl, 10-06-2003 04:03:08
Per my 2640 manual 30 ohms at empty and 0 ohms full. Also manual indicates Deere uses at least
two other sending units.
Earl
10-06-2003 10:10:30
Thanks Mike and Jake! That's a good idea about the ground and I will check that out this weekend. The sending unit is a JD unit and I checked the condition of the float when I removed it. The float was intact and the swing arm was moving freely. The gage is a JD unit and appears to be stock, so I should not have a compatibility problem between the sending unit and the gage. This weekend I will try to test the gage as suggested by F-I-T and/or test for an inadequate ground. It could very well be a problem with the ground because the instrument panel is adjacent to the battery compartment and is exposed to it's share of dust and corrosive fumes. Good stuff!
Jake
10-06-2003 07:16:18
Other things to check..... The case of the gauge needs a good ground to the dash, and the dash to the rest of the tractor. Also check your float to see that it is not leaking and partially full of fuel. This would cause it to float only 1/4 way up even with a full tank of fuel. If you have a bad float you can buy the float alone from your Ford car dealer. I'm not aware of anyone else selling the float by itself. Usually you need to buy the whole sender to get the float.
I can provide part number for the Ford float if you need it.
MIKE HANLEY
10-06-2003 06:21:01
I had truoble with the jeep gas gage and also when I convered the 730D to 12V from 24V. In both cases it was the ground, and in both cases I ran a wire from a mounting screw to bare metal. To check that everthing was working before I did that I removed the sender and with sender in hand, ground it and move the float up and down with your fingers and watch the gage. In the case of the diesels, when I went to Pos ground to Nev ground the gages would not work at all. I put in a universal 12V NEV groung senders and gages. 19 bucks at a auto supply store mail order place in Chicago.
MIKE HANLEY
10-06-2003 06:42:50
 Re: Re: Fuel Gage in reply to MIKE HANLEY, 10-06-2003 06:21:01
PS. I recall beening told when I was working on the gages, that you can't mix senders and gages and have them work rigth. Sometimes you get lucky and they will work. Most times they will not. In other words if the sender is a stock JD the gage must be from JD to match that gage. If putting on a univeral it should be in a set. I also remember reading something about that in the instructions that came with the univeral gages
F-I-T
10-06-2003 04:18:58
Earl:
Generally any kind of rheostat gauge like that will either show "EMPTY" or "FULL" when you ground the lead that goes to the sender. Just disconnect the sender lead and ground it to fresh metal, then turn on the switch. Gauge should show "E" or "F". If not, it could be poor connections, especially if the gauge works at all.
Frank
Earl
10-06-2003 05:22:00
 Re: Re: Fuel Gage in reply to F-I-T, 10-06-2003 04:18:58
Thanks F-I-T! That's exactly the kind of test that I was hoping for.
