4030 Brakes
Gary Mckenzie
01-21-2004 06:10:54
A friend's 4030 has developed a problem with the brakes on the right side, the pedal has become stuck. It's rock solid and will not move. The left side works normally. This happened without warning while using the tractor. Any ideas where to look first?
twopop
01-21-2004 18:00:12
 Re: 4030 Brakes in reply to Gary Mckenzie, 01-21-2004 06:10:54
from what i see in the manual,i would guess that the right hand plunger guide is stuck in the bore.you are going to need to remove the brake valve
Gary Mckenzie
01-22-2004 06:40:30
 Re: Re: 4030 Brakes in reply to twopop, 01-21-2004 18:00:12
Thanks, I'll check the valve out!
