4020 Diesel help
Ryan C.
10-05-2003 21:01:22
I'm 19 years old and bought a 1971 4020 Diesel Syncro range and plan on farming with my Dad. It's a sharp looking tractor, runs great, but sometimes it will not go into reverse. If you put it in 5th, pull forward a little, then pull it back into reverse, it's fine. Is it the syncronizers in the tranny, or does the linkages need adjusted. Thanks for any help.
Craig
10-06-2003 06:59:40
 Re: 4020 Diesel help in reply to Ryan C., 10-05-2003 21:01:22
My 2510 has done that exact thing for years. I adjusted linkage a few years back but didn't seem to help much. I wouldn't worry too much about it other than just the inconvenience of the problem.
I assumed the rear end was going out, but like I say, mine has done this for years. I shift alot too because I use mine with a loader.
david val
10-06-2003 01:40:45
you should of course, adjust it first per tm, then, if the problem persists...
anyway, before adjusting, check for excessive play in the shift mechanism.
david
twopop
10-06-2003 09:31:25
 Re: Re: 4020 Diesel help in reply to david val, 10-06-2003 01:40:45
david.I wish to respectfully disagree,I think first,check out the wear in the shift quadrant,then adjust the linkage.if the bushinds are replaced in the quadrant,then, the linkage probably wont need adjusting.
RJ-AZ
10-06-2003 20:09:37
 Re: Re: Re: 4020 Diesel help in reply to twopop, 10-06-2003 09:31:25
Thats rat David start at the top and work down. That slot macine shifter has some bushings inside that when replaced and lubed up solve a lot of problems. Also check shifter rod adjustment as well. Seems that I remeber some detents on the right side behind the battery box also. It gets real expensive to go into one of these.
