D model starting problem
Thomas F Donadi
10-05-2003 19:42:37
As you all can tell I am having problems getting my D to start. when i get a cylinder to fire the flywheel bounces backward some , it will not seem to get over to the next revolution. I do not always get it to fire just one quarter of the time and i do have a spark. I am baffled at this problem if any one can shed some light on this for me ,it would be greatly appreciated. thanks.
Spoker
10-09-2003 18:40:47
 Re: D model starting problem in reply to Thomas F Donadio, 10-05-2003 19:42:37
Thomas: Just wandering if you found the problem with the D starting. As Glen stated before the D came with an Edison Splitdorf CD magneto. And were later in years changed out to the Wico C and X magneto's as the splitdorf parts were getting hard to find. The D uses the long lug impulse drive coupling. As Cloony and John T stated the wires might be crossed, timing off, or impulse spring broken. I have a 1948 D which would start and run with a broken impulse spring, but it was hard to start and ran terrible. I first thought it was a fuel problem. Something told me to check for the impules snap of the mag instead of removing the carburator. I did and the mag did not snap. I removed the mag and replaced the impulse spring and it runs great. Those springs being broke can cause many of headachs. It will throw the mag out of time and if it starts it will some times turn the exhaust pipe red. If you can find a Wico X or C mag with the long lug coupling, replace the AP with one of the above. You can find them on eBay if you look under Wico Magneto or John Deere Magneto. You can buy them at a decient price some times on eBay. I bought two brand new Wico X and C mags on eBay last year that worked on my two D's for $350.00 for the pair. Good used ones for $65.00 to $100 maybe more. Best of luck. The D's are my favorite.
Clooney
10-06-2003 03:42:39
Thomas, what we know from your post that your spark is occurring too early so the flywheel is kicking back�. We can't tell you why until we know about what year your D is & the magneto make & model type.
~There were big differences between the early & late D�s as far as magnetos go & even significant differences in the same basic age group. That�s assuming you still have the original mag on it.
~Even the starting procedures are different between the early & late D�s & with different mags,
~Until you can tell us the year of your D & the magneto make & model [there should be a tag on it]. I will give you some basics to check that cover most D�s. [kind of general]
~If you have an early unstyled D make sure the timing advance lever is in the retard position [that�s the short lever next to the hand throttle lever]..
~If you have an early D make sure you are arming the mag [there should be an arming lever on the mag] to put it in the retard position for starting. [note: not on all mags]
~If your D has always started good & you are starting it the SAME WAY you always have & it is now kicking back when you turn the flywheel, suspect water or moisture in the mag or under the mag cap causing a cross fire.
~If your mag is functioning correctly & is armed correctly you should be able to slowly turn the engine flywheel in the running direction & hear the mags impulse snap [or click] as the L/H impulse [or spark retard] writing on the flywheel lines up with the case mark [at 3 o�clock behind the flywheel & even in height with the center of the crankshaft]�. My guess is it is snapping early before that lines up. The question is WHY?� If you haven�t moved anything, & are using the CORRECT starting technique, & there isn�t any moisture in the mag cap, you have something wrong with the mag like an inoperative impulse, or it has moved for some reason.
~As a quick test you might try swapping the plug wires in the mag cap just to see if they are in the wrong holes due to some kids playing with it or ?�
~If you can tell us the approximate year of your D, & the mag make & model [or try to explain what the mag looks like & where the wires come out] we will be able to give you a much more precise answer on where you problem might lie�.It would probably also help to know how it has always started before & how long ago it was starting correctly�
[email protected]
Thomas Donadio
10-07-2003 19:56:35
 Re: Re: D model starting problem in reply to Clooney , 10-06-2003 03:42:39
mr clooney in response to your to your follow up on the D model it is a 1946 and it has a wico type AP magneto. thanks I hope this will help you solve this problem of mine.
John T
10-05-2003 20:35:52
Hang in there Tom, Im sure the old girl will up n run soon. Anyway, that flywheel wanting to spin backwards sounds like the initial start timing may be too advanced meaning she fires just before TDC and tries to kick the piston back the wrong direction. Im not much of a D Man, Clooney and Duane and several others are sharp on them and Im sure they can add to this.
If you remove the plugs for easy cranking and slowly rotate the flywheel, when the Left Hand Impulse timing mark on the flywheel is in the 3 o clock position in line with a mark on the tractors side, THATS WHEN YOU SHOULD HEAR THE MAG SNAP TO FIRE. If it fires too soon before the flywheel is at that mark at 3 o clock, the start timing is too fast and she may kick the flywheel backwards.
Is it a governor mount or base moung mag, I forget?? If a governor mount, you adjust the start timing by loosenign the mags mount bolts and rotate it CCW to advance or CW to retard (sounds like you may need to retard it). Adjust it so you hear the mag snap to fire right when that Left hand Impulse mark passes the flat mark at 3 o clock NOT TOO MUCH BEFORE THEN. If a base mount, you loosen tne coupler and adjust its rotational position to make her fire same as before.
The timing is so it fires the left cylinder at its compression power stroke out the leadign cap tower (Left hand Impulse mark on Flywheel at 3 o clock in line with flat mark) and then 180 degrees of flywheel rotation later, it fires the right cylinder out the lagging cap tower on its TDC compression power stroke. On the non gear reduction mags (run at crankshaft RPM) that fire at BOTH TDC's (power and exhaust) if the mag was installed 180 out, a simpe wire reversal can make them run okay.
With the plugs removed you can find TDC and shes coming up on power compression when shes blowinG presure out the plugs hole (on exhaust stroke the exh valve will be open so she dont presure out the plug hole) and if the flywheel and other timing (cam and crank and governor) is correct, TDC will be when the Left hand Impulse mark is at 3 o clock. WHEN THAT HAPPENS, if the left plug fires, and then the right plug fires 180 later, ITS CORRECT. HOWEVER, if the right plug fires then (when left is at TDC) ITS WRONG, and depending on the mag, a wire reversal may cure it.
On the non gear reduced mags that fire on BOTH TDC's, if the wires are reversed from correct, she will usually pop and bang and backfire and raise all holy (*&&^% including maybe kick the flywheel backwards, but a wire reversal makes them okay.
SUMMARY
Check the basic timing and if the wires are right and if it fires the left plug on its TDC power and the right on its TDC power 180 later.
Next see if the mag snaps and fires when the Left Hand Impulse flywheel mark is at 3 o clock and adjust the start timing (rotate mag or adjust coupler) so she fires about then and not too much before.
Clean and gap the plugs and see how she does then or maybe even try a pull start and let us know what happens. Post back or e mail or call 812-824-4608 if you need more. You could have a fuel or carb or all sorts of other problems, but no need to go into all that unitl you get the igniiton about right and stop that flywheel kick back (probably start timign too fast). If this isnt correct for that D, hopefully some of the good D Men can enlighten us all and correct it.
Good Luck n God Bless.
John T
