HELP, Clooney-Power Steering
Stuart
10-05-2003 18:08:19
I tried to the advice u gave me to no avail.
I put in the correct John Deere Power steering oil in my 1954 John Deere 60 and it helped but it stilled foamed over. I dug out all of the steel wool i had in the breather and packed new felt. Then I tried running it a little low and that didnt help.It did get better after new oil and the new felt but it still does it.
Is my pump getting air some where as there are no gaskets between the pump halfs. If it was getting air when it is running then it should leak when turned off shouldnt it???
I am not sure what to do, plus i am aggitated by all of the work i have done with no results( sorry just venting) Any help would be greatly appreciated. When I drain the ATF out of the resivoir the first time I flushed it good so I am sure there is no contamination.
What is up? Thanks for all of your generous help.
Clooney
10-05-2003 18:54:29
 Re: HELP, Clooney-Power Steering in reply to Stuart, 10-05-2003 18:08:19
Stuart, it definitely sounds like you are sucking in air from somewhere.
~The most likely place is one of the pump seals. [there is a double direction seal on both the front & rear of the P/S pump].
~Start by going over all the pipes & fittings on the SUCTION side of the system. If you can't find an air leak in the suction pipes or fittings you probably have a pump seal problem. [put a little P/S oil in a pump oil can & put a little around the fittings, if it sucks the oil in you have found the leak]
~You might try draining the P/S oil then add a slight pressurization with some freon at the cap vent then use a freon leak sniffer around the front fan shaft seal & inside the crankcase as well as the return line & fittings. Problem is, you might only be sucking air in & not leaking the other direction so might not find the problem with pressure. Just because it sucks air doesn't mean it will leak oil, air is much thinner than oil.
~The last tractor I worked on with an air intrusion problem turned out to be the rear pump seal [at least I think, as I put new pump seals in & the air bubbles stopped]. ~Are you sure the cap vent is open & working? If the cap vent is plugged up it will try to suck air in anywhere it can [that's usually under the seals]..
~One last thing to check, make sure the engine crankcase is breathing freely. If the crankcase is building excess pressure it could force some of the crankcase pressure by the rear P/S pump seal...
